99 Ram 2500 V10 with a tick tick tick noise. #2713781
11/07/19 05:39 PM
11/07/19 05:39 PM
Sonoran desert, Arizona, USA
moparjo68 Offline OP
99 Ram 2500 with 153,000 and a V10 that all of a sudden starting a tick tick tick noise while running/idling. The noise came on instantly. I immediately did a compression test. High number was 160. Low number was 135. I saw a youtube video that someone had the same ticking noise as my truck engine. He removed the valve cover and a rocker arm bolt had sheared off causing the tick noise.
My question is: Without removing the valve covers to look for broken/loose rocker arm bolts, would the compression test readings tell me what I need to know.
Meaning: wouldn't I get a real low reading if the intake valve can't open and no air is able to enter the cylinder on the piston's downward stroke?
Re: 99 Ram 2500 V10 with a tick tick tick noise. [Re: moparjo68] #2713785
11/07/19 05:57 PM
11/07/19 05:57 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
This isn't answering your question but the first thing I do when I hear a "tick" is to get out the stethoscope. You can isolate the area where the "tick" is coming from.
It could be an exhaust leak.
Re: 99 Ram 2500 V10 with a tick tick tick noise. [Re: moparjo68] #2713799
11/07/19 06:57 PM
11/07/19 06:57 PM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
One of those video boroscopes with a camera head less than 9 mm in diameter might be able to get in and let you see the valve train. The USB borescopes that attach to cell phones or tablets are very reasonably priced now.
Re: 99 Ram 2500 V10 with a tick tick tick noise. [Re: moparjo68] #2713801
11/07/19 07:02 PM
11/07/19 07:02 PM
AndyF Offline
AndyF  Offline
My 2004 Dodge Ram 1500 has had a ticking noise since it was new. The only time I really hear it is when I pull into the drive thru window at the bank. When I'm inside that drive thru tunnel I can hear a tick tick tick. No idea what it is, been that way for 15 years without fixing itself or getting worse.
Re: 99 Ram 2500 V10 with a tick tick tick noise. [Re: AndyF] #2713842
11/07/19 09:33 PM
11/07/19 09:33 PM
I tried to use the stethoscope before I posted to pinpoint the noise but it didn't help me. The best I can pinpoint, it sounds like its coming from drivers side. When the noise first started, I was driving it...............and I felt a power loss...............like the loss of a cylinder. I checked all plug wires. They are all snug. Also, I made sure each cylinder was getting fire......and they are.
Re: 99 Ram 2500 V10 with a tick tick tick noise. [Re: moparjo68] #2713890
11/08/19 08:42 AM
11/08/19 08:42 AM
ohio
67mprfan Offline
67mprfan  Offline
ohio
Possible crack in the exhaust manifold Or warped on the face of the manifold
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: 99 Ram 2500 V10 with a tick tick tick noise. [Re: moparjo68] #2713902
11/08/19 09:43 AM
11/08/19 09:43 AM
Guitar Jones Offline
160 to 135 is too much of a difference between cylinders if you ask me. Yes the compression will be lower if the intake valve can't open at all, might be higher if the exhaust can't open but even if they partially open then compression will be affected. I think you need to pull the rocker covers.
Re: 99 Ram 2500 V10 with a tick tick tick noise. [Re: Guitar Jones] #2714019
11/08/19 04:11 PM
11/08/19 04:11 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Mine had a similar issue and with a dead miss.
Pulled valve covers and found broken bolt in the rocker arm stand
Re: 99 Ram 2500 V10 with a tick tick tick noise. [Re: gtx6970] #2714027
11/08/19 04:46 PM
11/08/19 04:46 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Quote
The same exact thing happened to mine with 48K miles on it.
Pull a valve cover & take a look.
Re: 99 Ram 2500 V10 with a tick tick tick noise. [Re: Alaskan_TA] #2715768
11/14/19 04:02 PM
11/14/19 04:02 PM
OK. Here's an update. I just removed the valve cover from driver's side. The valve train looks good. No sheared off bolts. Everything is snug. No loose parts. No broken valve springs. But here is what really concerned me. I noticed small traces of anti freeze pooling in the head. What does that mean?
Re: 99 Ram 2500 V10 with a tick tick tick noise. [Re: moparjo68] #2715795
11/14/19 04:51 PM
11/14/19 04:51 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
That means really bad things.
Most likely culprit is a crack in a cylinder head.That's the only way i can think of coolant getting under the valve cover other than being blown in through the breather. That, in itself, would also be a very bad thing.
We are brothers and sisters doing time on the planet for better or worse. I'll take the better, if you don't mind.
- Stu Harmon
Re: 99 Ram 2500 V10 with a tick tick tick noise. [Re: feets] #2715963
11/14/19 11:06 PM
11/14/19 11:06 PM
I was afraid when I saw the anti freeze under the valve cover that the motor was toast. I just stopped working on it and figured its time to hunt another v10.
Re: 99 Ram 2500 V10 with a tick tick tick noise. [Re: moparjo68] #2716182
11/15/19 06:49 PM
11/15/19 06:49 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
First thing I would do is crack the drain plug in the oil pan and see how much green comes out first. Then I'd pressure test the cooling system before I went into panic mode.
Kevin
Re: 99 Ram 2500 V10 with a tick tick tick noise. [Re: Twostick] #2716205
11/15/19 07:43 PM
11/15/19 07:43 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Kevin
This ^
Re: 99 Ram 2500 V10 with a tick tick tick noise. [Re: gtx6970] #2730965
01/07/20 11:13 PM
01/07/20 11:13 PM
Update: I did a coolant pressure test on the dodge V10. I pumped it up to 15-16 lbs. After about two hours, it had only dropped to 14 lbs. Looking down into the radiator, the coolant looks oily but draining the oil from the crankcase, I didn't notice oil and anti-freeze mixed together. Any thoughts?
