Page 3 of 3 1 2 3
Re: Who has done a Pro-Street Hellcat Crate deal? [Re: Dragula] #2684844
08/06/19 01:10 AM
08/06/19 01:10 AM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
Originally Posted by Dragula
Any updates with all the pulleys and stuff installed?
Sorry, been super busy wiring, running the fuel system, etc. Hoping to fire this thing up in a week or so. I have to pull the radiator and front support, I need to change the lower water pump fitting , so I will take some pics of the front when I remove that. Then you can get a good clear view of everything.
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Who has done a Pro-Street Hellcat Crate deal? [Re: DemonDust] #2685454
08/07/19 06:56 PM
08/07/19 06:56 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
Why is there a crap load of ads in my reply?
SDG Motorsports
Re: Who has done a Pro-Street Hellcat Crate deal? [Re: DemonDust] #2685980
08/09/19 11:24 AM
08/09/19 11:24 AM
Nebraska
70VcodeCoronetRT Online tonguue
70VcodeCoronetRT  Online Tonguue
Nebraska
So I shouldn't need to cut the firewall on my 70 Challenger? The Hellcrate is really 800lbs? If I can run a CRT buitl 727 with this. I might have to bite the bullet. Anyone else with real world performance numbers?
Re: Who has done a Pro-Street Hellcat Crate deal? [Re: 70VcodeCoronetRT] #2686016
08/09/19 12:54 PM
08/09/19 12:54 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
John Ketron had no issues putting a hellcat in a Cuda. To my knowledge only A and B bodies need the low profile water manifolds. With the water manifolds we designed there is no need to cut any firewall.
SDG Motorsports
Re: Who has done a Pro-Street Hellcat Crate deal? [Re: DemonDust] #2691726
08/26/19 09:22 PM
08/26/19 09:22 PM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
Got these sent to me today.....Looks awesome. The only things I would be worried about going this route:
1 Is the water pump enough to keep it cool in 100 degree heat.....
2. Can there be any less pulleys or idlers used to keep it simpler?
'70 Cuda,...605 EFI Hemi Street Car (6.20 best pass, 1.33 60ft)
Re: Who has done a Pro-Street Hellcat Crate deal? [Re: Dragula] #2692127
08/28/19 12:30 AM
08/28/19 12:30 AM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
I can't answer your question on the water pump, it is the high flow pump so I hope it will keep cool. But the pulleys are required. You need at least 180° wrap on the super charger and 180° wrap on the balancer. Factory hellcat, demon, and Hellephant all use this number of pulleys.
SDG Motorsports
Re: Who has done a Pro-Street Hellcat Crate deal? [Re: DemonDust] #2692134
08/28/19 12:54 AM
08/28/19 12:54 AM
LA & L.A.
MoparPosterChild Offline
LA & L.A.
We are putting one in my 70 Cuda convertible and we cut the firewall to clear it.
2018 Dodge DEMON #18
1970 Plymouth Duster 406" Stroker
1969 Charger 500" Stroker
1964 Dodge Polara 426 GEN III HEMI
1970 Plymouth Cuda Hellcrate Project car
1974 Dodge Ramcharger Project car
2017 Chrysler Pacifica Limited
2017 Ram 3500
2012 Dodge Caravan R/T
1972 Charger Mopar 392 HEMI Stolen
2008 Challenger SRT-8 Gone
2010 Challenger SRT-8 Gone
2006 Charger SRT-8 Gone
2007 Charger R/T Gone
Re: Who has done a Pro-Street Hellcat Crate deal? [Re: MoparPosterChild] #2692216
08/28/19 10:13 AM
08/28/19 10:13 AM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
You should have used these, they are in stock and ready to ship, if you haven't cut the firewall yet.
SDG Motorsports
Re: Who has done a Pro-Street Hellcat Crate deal? [Re: DemonDust] #2692415
08/28/19 08:58 PM
08/28/19 08:58 PM
Dragula Offline OP
Dragula  Offline OP
I figured it is the way it has to be, but I kinda always question everything.....Not trying to be negative. Have you done anything else to the engine like cam or injectors? Looks like you went for the ATI damper for +10%....
Do you know what it ended up weighing?
I figure my car is currently good for 9.60's, but I have to upgrade the roll bar to a cage...
Re: Who has done a Pro-Street Hellcat Crate deal? [Re: Dragula] #2692419
08/28/19 09:09 PM
08/28/19 09:09 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
This is actually a 6.1, Molnar crank and rods, custom Wiseco pistons, Hellephant cam, 1600cc injectors, 96mm direct fit cable driven TB,10% lower, 2.75 upper, running on corn. No idea what it weighs. It should outrun my cage that's all I want.
SDG Motorsports
Re: Who has done a Pro-Street Hellcat Crate deal? [Re: DemonDust] #2692420
08/28/19 09:15 PM
08/28/19 09:15 PM
Dragula Offline OP
Dragula  Offline OP
Wow...How many cubes? I was thinking of doing it that way. I have brand new proted Eddy heads....
Re: Who has done a Pro-Street Hellcat Crate deal? [Re: Dragula] #2692477
08/28/19 11:58 PM
08/28/19 11:58 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
It's 394 ci. Mine are 6.1 stage 5 CNC Port arrington heads. Not sure what the stage 5 stands for.
SDG Motorsports
Re: Who has done a Pro-Street Hellcat Crate deal? [Re: DemonDust] #2693774
09/02/19 09:21 PM
09/02/19 09:21 PM
Dragula Offline OP
Dragula  Offline OP
Post a pic or two when you get the plate and accessories all plumed and hooked up....
Page 3 of 3 1 2 3
