Carb gasket, heat shield???
#2666476
06/16/19 11:44 AM
06/16/19 11:44 AM
Posts: 2,806 Northern NJ
StukaJU87
Northern NJ
The intake for my 383 is painted and will be ready to install in a couple days.
Intake is stock 2806301 4 barrel.
The spacer I took off appears to be made of wood.
I have air grabber on my car.
What gasket or shield is recommended by you guys?
Scott
1969 Super Bee, 383/4 speed
Re: Carb gasket, heat shield???
[Re: StukaJU87]
#2666492
06/16/19 12:22 PM
06/16/19 12:22 PM
How thick was the wood spacer & are you wanting to replace it with a regular gasket?
[Re: RapidRobert]
#2666506
06/16/19 01:43 PM
06/16/19 01:43 PM
StukaJU87
Northern NJ
How thick was the wood spacer & are you wanting to replace it with a regular gasket? I'd say about 1/4" or so thick. I was just wondering if there was something thinner and just as effective that you guys were using.
Scott
[Re: topside]
#2666580
06/16/19 05:08 PM
06/16/19 05:08 PM
Posts: 6,212 nowhere
Sniper
nowhere
Wood is the best isolator material. Heck, at one time, someone - maybe Mr Gasket? - sold an asbestos gasket stack. That ain't gonna happen again! As far as a heat shield, the best I've used is a GM one; IIRC its application was for a Holley on early Z/28. Works great under a Holley on a BB Mopar, or anything else for that matter. I don't know if the architecture of an AVS would benefit as much, being that the bowls are on the sides vs fore & aft. Holley heat shield GM pn 3969835
[Re: StukaJU87]
#2666637
06/16/19 07:55 PM
06/16/19 07:55 PM
Posts: 11,992 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Are you gonna block the crossover?
Master, again and still
[Re: DaveRS23]
#2666645
06/16/19 08:08 PM
06/16/19 08:08 PM
StukaJU87
Northern NJ
Are you gonna block the crossover? I have the new pan with the crossover blocked, but I'm having 2nd thoughts about using it because I still want to run the stock choke.
Scott
[Re: StukaJU87]
#2666749
06/17/19 08:49 AM
06/17/19 08:49 AM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
The choke well does need the heat from the crossover to work right, but that heat will boil the fuel in the carb in hot weather with today's gas. And as thin as an insulator under the carb will have to be, it won't help much. The original style intake and carb were good stuff at the time, but they were designed to work with a very different gasoline than they see today.
[Re: DaveRS23]
#2666779
06/17/19 10:01 AM
06/17/19 10:01 AM
Posts: 1,317 Ohio
jlatessa
Ohio
What we did on our 6 pack choke , (we use the blocked pan) was fab in a heat coil used on some chokes and turn it on when starting to increase available heat to the coil.
We use a lighted on-off switch mounted in the ash tray for about 5 minutes. Then the engine heat migrates enough to keep it open.
Joe
[Re: dOc !]
#2667010
06/17/19 08:49 PM
06/17/19 08:49 PM
StukaJU87
Northern NJ
I appreciate all the replies. What I had worked pretty well until the choke well developed a hole in it.
I have everything unbolted. Old manifold ready to pull. I have never had it off the car.
Gonna wait till later in the week when my brother can come over so I have an extra set of hands for the job.
Scott
Re: UPDATE!!
[Re: Stanton]
#2668718
06/22/19 01:44 PM
06/22/19 01:44 PM
StukaJU87
Northern NJ
UPDATE: I'd bet its Phenolic and not wood. Stanton wins. Def not wood. seemed like compressed material of some sort. After removing the bad manifold I found the left side head heat crossover plugged with some sort of super solid stuff, so I left that. The right side by the choke well was open, so I left that too. I am using the factory choke setup. I reused the pan gasket only adding felpro papers to the top side between the manifold and tin. Torqued it down and reassembled all the loose bits I had removed. Fired that thing up. Ran it on the choke for a few minutes and when the choke came off it was still idling a bit high. I adjusted that and it idled perfectly and drove great. That manifold must have been leaking for quite a while because it idles perfectly steady now.....unlike before. Thank you to 68CBarge and everyone of you that helped me along the way!!!!
Scott
[Re: dOc !]
#2668728
06/22/19 02:17 PM
06/22/19 02:17 PM
Posts: 553 DE
Ply72rr
DE
Any of you guys remember what Chrysler did in the high load BIG HEAT 413s in the trucks and motor home motors ? No, what did they do?
[Re: Ply72rr]
#2668762
06/22/19 04:46 PM
06/22/19 04:46 PM
Posts: 30,424 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
Any of you guys remember what Chrysler did in the high load BIG HEAT 413s in the trucks and motor home motors ? No, what did they do? They ran COOLANT in the exh heat crossover !!
[Re: dOc !]
#2668767
06/22/19 05:11 PM
06/22/19 05:11 PM
Posts: 4,702 Florida
BDW
