holley 4393 #2657678
05/21/19 06:31 PM
05/21/19 06:31 PM
TN
1DGEMAN Offline OP
1DGEMAN  Offline OP
TN
I have a Holley 4393 carb 1219 date for an A12. The metering plate has a Holley pn 34R 5113 B. Where the number should be on the plate has gouges like grind marks and is stamped 6178 which is the correct number for the carb. So my question for the gurus, is that Holley part number correct to be a real 6178 plate? I hope some one has an original unmolested 6178 plate or a Holley reference book so this can be verified.
Thanks, Rod
Real Men shift for themselves
Re: holley 4393 [Re: 1DGEMAN] #2657698
05/21/19 07:03 PM
05/21/19 07:03 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
4393 front ,6178 plate
4394 rear , 6180 plate
Re: holley 4393 [Re: 62maxwgn] #2657826
05/22/19 12:30 AM
05/22/19 12:30 AM
TN
1DGEMAN Offline OP
1DGEMAN  Offline OP
TN
You missed the question. If you read my post I say I know 6178 is the correct number. This plate appears to be altered so the question is......is a 6178 plate Holley pn 34R 5113 B?
Re: holley 4393 [Re: 1DGEMAN] #2657887
05/22/19 08:42 AM
05/22/19 08:42 AM
South Bend
John Brown Offline
John Brown  Offline
South Bend
No, it is 34R-6178
Re: holley 4393 [Re: John Brown] #2657893
05/22/19 08:50 AM
05/22/19 08:50 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Half wrong,half right.
Re: holley 4393 [Re: 62maxwgn] #2657927
05/22/19 10:05 AM
05/22/19 10:05 AM
South Bend
John Brown Offline
John Brown  Offline
South Bend
http://www.dodgecharger.com/forum/index.php?topic=99406.0
Skip down to the SIX PACK carb numbers section.
Re: holley 4393 [Re: John Brown] #2657989
05/22/19 12:47 PM
05/22/19 12:47 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
The part number 34R 5113 B is the casting number for the correct plate,the 6178 is plate reference number for carb application
Re: holley 4393 [Re: 62maxwgn] #2658027
05/22/19 02:12 PM
05/22/19 02:12 PM
TN
1DGEMAN Offline OP
1DGEMAN  Offline OP
TN
Perfect thank you that pic is just what I wanted.
