426 hemi valve covers leaking?
#2656995
05/19/19 07:37 PM
05/19/19 07:37 PM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
My car came with 2 cork gaskets on covers. i had to change the head gaskets so i put 2 new cork gaskets back twice and still won't stop leaking! even put a little rtv. any suggestions?
Hell Hath No Fury Like Mine
Re: 426 hemi valve covers leaking?
[Re: sixpacksteve]
#2657000
05/19/19 07:58 PM
05/19/19 07:58 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
Why would it need 2 gaskets? I have always used cork on valve covers. Make sure everything is clean and flat. Sometimes a little silly cone to fill gaps. Cork is a soft materiel don't over tighten.
[Re: bboogieart]
#2657002
05/19/19 08:07 PM
05/19/19 08:07 PM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
i was just coping what was on the car! and didn't want any problems.
[Re: sixpacksteve]
#2657009
05/19/19 08:16 PM
05/19/19 08:16 PM
bboogieart
Lost and Spaced
I understand. Problem is you might have been copying a band aid.
[Re: sixpacksteve]
#2657138
05/20/19 08:45 AM
05/20/19 08:45 AM
Posts: 11,988 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I use the reinforcements around the bolt holes. They needed some slight modifications since they are meant for shivvies, but they helped. I have also had good luck using Superformance gaskets against the head with a cork/rubber gasket glued to them and against the cover. The cork tends to mash out around the thin head rail but the Superformance holds up there better. While the cork follows the contours of my steel valve covers better than the harder gaskets.
Typically Hemiroid, it takes $100 and a lot of work just to gasket the valve covers. And mine are pretty good, but are not bone dry.
Master, again and still
[Re: sixpacksteve]
#2657181
05/20/19 10:47 AM
05/20/19 10:47 AM
Posts: 15,264 Omaha Ne
TJP
Omaha Ne
My car came with 2 cork gaskets on covers. i had to change the head gaskets so i put 2 new cork gaskets back twice and still won't stop leaking! even put a little rtv. any suggestions? 1. Establish what area the leak(s) are coming from 2. Remove and check for the impression of the head seal in the bottom of the gasket. This can go a LONG ways towards identifying the problem / area 3 . Try setting the valve cover on the head without gaskets and "rocking" it Checking for flatness. 4. Check the areas surrounding the bolt holes as they sometimes get stretched ( depressed) from over tightening. If so re level using a small hammer and dolly. Two gaskets are sometimes used because of a sealing problem or to allow additional rocker arm clearance. When doing so I always put sealer between the two. Also might want to check and verify that you are not building too much crankcase pressure
[Re: Cab_Burge]
#2657296
05/20/19 07:03 PM
05/20/19 07:03 PM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
ok, will do! but should i use cork or felpro?
[Re: sixpacksteve]
#2657317
05/20/19 08:05 PM
05/20/19 08:05 PM
Posts: 43,095 Bend,OR USA
Not rubber or neopreme only, maybe a mix of stiff cork and rubber How many different types of valve cover gaskets does Fel Pro offer now?
[Re: Cab_Burge]
#2657670
05/21/19 06:22 PM
05/21/19 06:22 PM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
the covers look like an aftermarket chrome, i'm guessing the 2 gaskets were for clearance for stage v rockers. as there were marks on inside of covers! So No rtv Nothing?
