Removing horn ring? #2648564
04/24/19 06:06 PM
04/24/19 06:06 PM
AndyF Offline OP
AndyF  Offline OP
So how do I remove the horn ring from a 1965 Dodge Coronet 500 steering wheel? My FSM doesn't have a steering column section in it. I have newer FSMs but I'm not sure the directions are the same. The '67 manual says to twist the horn ring CCW to remove but that doesn't seem to work with my '65.
Re: Removing horn ring? [Re: AndyF] #2648568
04/24/19 06:31 PM
04/24/19 06:31 PM
The Sunny Shuswap
dodgefarmer Offline
dodgefarmer  Offline
The Sunny Shuswap
Push down. Turn CCW.
HTH
Randy
Re: Removing horn ring? [Re: dodgefarmer] #2648576
04/24/19 07:08 PM
04/24/19 07:08 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
HTH
Randy
UHH Disconnect battery or horn relay first LOL laugh beer grin
Re: Removing horn ring? [Re: dodgefarmer] #2648670
04/24/19 11:53 PM
04/24/19 11:53 PM
AndyF Offline OP
AndyF  Offline OP
HTH
Randy
Thanks that worked. There was some corrosion built up on the contacts so I had to push a little harder than I thought but in the end it came apart okay. Now I just need to figure out how to take everything else apart in there!
