Tranny Swap #2646589
04/18/19 07:37 PM
04/18/19 07:37 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
89 Dakota 3.9 2WD. Can I put a 3 speed in place of the 4 speed?
Grandma always said I had "hands of gold"!
Re: Tranny Swap [Re: CHRGR69] #2646628
04/18/19 09:50 PM
04/18/19 09:50 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I have a dumb question stick or auto?
Re: Tranny Swap [Re: stumpy] #2646637
04/18/19 10:15 PM
04/18/19 10:15 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
Not dumb. Auto
Re: Tranny Swap [Re: CHRGR69] #2646642
04/18/19 10:21 PM
04/18/19 10:21 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
replace a 4 speed with a 3..... why? I have gone the opposite way before on an 88 D100.
Re: Tranny Swap [Re: volaredon] #2646654
04/18/19 10:59 PM
04/18/19 10:59 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
Just asking because I'm coming across them more often than the 4 speeds.
Re: Tranny Swap [Re: CHRGR69] #2646662
04/18/19 11:42 PM
04/18/19 11:42 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
You can, but the 4 speed auto is longer then the 3 speed auto of the same size (904/A500 or 727/A518).
My luck with used automatic transmissions aren't very good. I would spring to have the one you have rebuilt, or buy a rebuilt trans from an online source. Gene
Re: Tranny Swap [Re: poorboy] #2648784
04/25/19 11:12 AM
04/25/19 11:12 AM
CHRGR69 Offline OP
CHRGR69  Offline OP
That's what I'm leaning towards.
Re: Tranny Swap [Re: CHRGR69] #2650364
04/29/19 09:31 PM
04/29/19 09:31 PM
Cruising!
Q
QuickDodge Offline
QuickDodge  Offline
Q
Cruising!
I haven't attempted such a swap, but suspect it could be done. Some parts swapping and perhaps a bit of minor fabrication may be required. The older 904's had mechanical speedometer drives. I think the transmission mounts may be in different locations. No idea how the computer would react to the transmission swap.
Some people buy a manual or video and rebuild the transmission themselves. The 3 speed transmission are rumored to be easier to rebuild than the overdrives.
With the 3 speed transmission, you may want to consider changing the rear axle ratio if you plan to drive it on the highway.
Personally, if it was my truck and the money was available, I'd follow Gene's recommendation!
