Rookie Q: How to troubleshoot a whining 742 diff...
#2646089
04/17/19 02:44 PM
04/17/19 02:44 PM
Posts: 7,538 Albany, NY
67SATisfaction
The member whose name is actually Art
Albany, NY
Thanks for looking - I've had Mopars for many years, but differentials and axles are unknown territory for me: I've got a '65 Satellite with a 742 diff and it's has a mild, off-throttle, whining sound.
1.) Is this sound causing harm? (I think not, cuz I lived with a whiny diff in a /6 Dart for over 200,000 miles). 2.) How is a 742 adjusted for noise like this? .... if that's even the right question to ask?
Background: The 8-3/4" rear end of this car was ALWAYS noisy. It grumbled and growled for about 5,000 miles, took a wicked sudden turn for the worse in 2017 and it was obviously a bad rear bearing. I had a lengthy painful thread here about this. The short story is the old bearing wouldn't come out. It also showed evidence of having been tried removed before, but a previous owner left it and gooped red silicone in the bearings to seal them or some such nonsense. I broke a bearing puller trying, but couldn't pull the axles out past the stuck bearing race. So I cut through the axle tube, destroying the axle housing, and went searching for new 8-3/4" axle housing.
I kept the 742 diff and the old axles with blue/green paint marks.
I bought a used 8-3/4" axle housing with axles but not the diff from a local Mopar buddy. I refurbished the housing, stuck new OEM cone bearings on the axles, put the 742 pumpkin and inserted the axles easy peasy. The "new" axles have white paint marks.
The growling sound is gone, but a whining sound remains. It happens only off-throttle, sometimes not at all, but usually gently coasting. (My '67 Satellite has its original 741 rear diff and is 100% quiet in comparison). The whining is not bad enough to transmit any vibrations into the car.
I thought the "new" axles are matched to the "new" axle housing they came from and fit right in with no adjustment needed.
Thanks, - Art
65 Satellite hardtop 361/4bbl console 727 2.76 67 Satellite convert 383/2bbl column 727 3.23 67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd 67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd 71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd 82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle 75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF 77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF 07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
Re: Rookie Q: How to troubleshoot a whining 742 diff...
[Re: 67SATisfaction]
#2646097
04/17/19 03:00 PM
04/17/19 03:00 PM
Posts: 14,889 up yours
Supercuda
It never ceases to amaze me the amount of major work people will do without even looking at the FSM.
Right out of the 65 FSM, adjusting your axle end play, though that's probably not the only issue. Sounds like yout pinion to ring gear pattern is off. That would also b ein the FSM with pictures of what is good and what is not good.
[Re: Supercuda]
#2646122
04/17/19 04:46 PM
04/17/19 04:46 PM
Posts: 25,729 Rio Linda, CA
John_Kunkel
IMHO, once a ring & pinion makes noise and runs for any length of time you're not going to adjust the noise away.
[Re: John_Kunkel]
#2646141
04/17/19 05:47 PM
04/17/19 05:47 PM
Posts: 20,622 in a cattle trailer down by th...
Guitar Jones
IMHO, once a ring & pinion makes noise and runs for any length of time you're not going to adjust the noise away. I agree, of course though it most likely isn't hurting anything either.
[Re: John_Kunkel]
#2646193
04/17/19 07:30 PM
04/17/19 07:30 PM
Posts: 15,279 Omaha Ne
TJP
Omaha Ne
IMHO, once a ring & pinion makes noise and runs for any length of time you're not going to adjust the noise away. You may want to check the pinion nut and make sure it is tight with no end play present. If neither of those are at fault The only way to get rid of it is louder mufflers (LOL), and from you description doubtful anything will get hurt. The axle end play should always be checked.
[Re: TJP]
#2646215
04/17/19 08:35 PM
04/17/19 08:35 PM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
IMHO, once a ring & pinion makes noise and runs for any length of time you're not going to adjust the noise away. You may want to check the pinion nut and make sure it is tight with no end play present. If neither of those are at fault The only way to get rid of it is louder mufflers (LOL), and from you description doubtful anything will get hurt. The axle end play should always be checked. Only easy check is the pinion nut to make sure the pinion pre-load did not slack off as mentioned above.
[Re: topside]
#2646354
04/18/19 08:17 AM
04/18/19 08:17 AM
Posts: 5,100 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
FWIW I've found lower ratio's sometimes whine a little more than higher ratio's... I know my 3.91 makes a little more sound than the 3.23 does... A local guy to me sets up a lot of rears in the area...Street cars...drag cars...whatever...The one thing he doesn't do is guarantee they won't make any noise... Some rears can be set up perfect and will still whine...
...FAFO...
[Re: skicker]
#2646363
04/18/19 08:36 AM
04/18/19 08:36 AM
67SATisfaction
Albany, NY
Thanks all,
I'll start by checking the pinion bearing. That's the advice I was looking for - where to start. I've sourced an FSM, and will use it to educate myself, just didn't know where to start troubleshooting this. I'll check the other items you suggest after that. Axle end play was fine after the work last year.
It's an AC car with a 2.76 ratio, open diff. The whine is something I could live with - it's not very intrusive. But you know how once you hear a noise it gets under your skin and if it's a system you don't know much about, you gotta start asking. I drove the '65 all last week, played with the throttle to check it out, but the difference *really* hit me when I switched to the '67 Satellite (741 with 3.23 ratio) - that thing is completely silent, so it got me wondering.
I'll have the '65 back next week. If I find something worth sharing I'll post it here.
Cheers, - Art
[Re: FurryStump]
#2646544
04/18/19 05:17 PM
04/18/19 05:17 PM
Guitar Jones
The 742 case has shims for the pinion preload so you can just make sure the pinion is torqued to spec. Like stated above if the noise is not increasing than it is probably not eating itself and you could go crazy attempting to get rid if the noise. Some just make noise. I did a lot of ring and pinions back in the day for whining. I think Mopar stamped those things out with an axe.
[Re: dogdays]
#2651383
05/02/19 09:52 PM
05/02/19 09:52 PM
67SATisfaction
Albany, NY
Thanks all - the sound is almost gone - here's an update..
I drove the car home from the storage garage, listening the whole time. The whine came only "off throttle", and a lot of the time just not there at all. The sound wasn't really *that* loud after all.. was I dreaming the time I heard it so loud? ...maybe it's quieter with stiffer cold oil?
The next morning, I jacked the rear up, got the driveshaft off the yoke and checked how much play there was in the pinion bearing, just using my hands to yank on the yoke. There was no sideways play, and just a tiny bit of endplay... 1/16"? I noticed a drop of oil hanging from the bottom of the chunk, although nothing had dripped on the floor. The oil looked like it was probably weeping from the pinion seal. I checked elsewhere on the chunk and decided to check the torque on all the axle housing nuts. Well, I was able to tighten each nut a good full rotation. Even though I don't know the torque spec, I tightened them all as equally as I could. I did check the diff oil level last fall, it was right there near the edge of the filler port.
The whine is now imperceptible at speeds above 35-40.. above that speed the noise of the car itself makes it impossible to hear. I'll keep an eye out for oil drips and the oil level. So thanks for walking me through this.. - Art
