source for 3/4" tall o2 sensor bungs #2645437
04/15/19 04:32 PM
04/15/19 04:32 PM
Minnesota
Hemi_Joel Offline OP
Minnesota
I am planning to set up a pair of headers for dyno testing with 8 O2 sensors. (because I have 8 carbs) I bought some weld bungs from summit, but they are only 1/2 thick. The O2 sensor protrudes 1" past its flange, so that would leave 1/2" of the sensor in the tube. The dyno guys says that is enuff to affect performance. Does anyone know of a source for 3/4" thick steel O2 bungs. M18x1.5 is the thread. Thanks,
Joel
[img]http://i.imgur.com/boeexFms.jpg[/img]
31 Plymouth Coupe, 392 Hemi, T56 magnum
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
I don't regret the things I've done. I only regret the things I didn't do.
"Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
Re: source for 3/4" tall o2 sensor bungs [Re: Hemi_Joel] #2645454
04/15/19 05:07 PM
04/15/19 05:07 PM
pittsburghracer Offline
Check out Amazon. Lots of different ones on there.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: source for 3/4" tall o2 sensor bungs [Re: pittsburghracer] #2645465
04/15/19 05:43 PM
04/15/19 05:43 PM
Minnesota
Minnesota
I've been searching the web including amazon, ebay and summit. The search functions and descriptions mostly omit length. I'm hoping someone here knows a source.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: source for 3/4" tall o2 sensor bungs [Re: Hemi_Joel] #2645469
04/15/19 06:00 PM
04/15/19 06:00 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Weld 2 bungs together
Re: source for 3/4" tall o2 sensor bungs [Re: Hemi_Joel] #2645474
04/15/19 06:19 PM
04/15/19 06:19 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Check O'Reilly's.
Re: source for 3/4" tall o2 sensor bungs [Re: justinp61] #2645486
04/15/19 07:16 PM
04/15/19 07:16 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I have an old Dynomax 88103 here that's 5/8" thick. Not sure I've ever seen one thicker. The threads on the sensors aren't that long. I suppose you could weld a bung to a thick washer/spacer and weld that assembly onto the pipe.
Re: source for 3/4" tall o2 sensor bungs [Re: Hemi_Joel] #2645500
04/15/19 07:55 PM
04/15/19 07:55 PM
Are you interested in the dyno readings on the HP and torque or the accuracy of the O2 readings from each pipe?
I allowed a dyno operator to install 8 O2 bungs in my race car headers to dyno a B 1 motor I built for a customer several years ago, that motor had a cast single plane dominator flange manifold, not much carb. tuning was done on that test work
On your deal I would install them and tune the motor and then remove them to see if the probes sticking into the headers affected the readings or not twocents scope up grin
Re: source for 3/4" tall o2 sensor bungs [Re: Cab_Burge] #2645556
04/15/19 10:22 PM
04/15/19 10:22 PM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
The only Carbs I care about are under the hood!
Re: source for 3/4" tall o2 sensor bungs [Re: Azzkikrcuda] #2645559
04/15/19 10:30 PM
04/15/19 10:30 PM
n.c.
geo. Offline
geo.  Offline
n.c.
Take a look at the old spark plug anti foulers, the stores may carry them under the help line.
Might be something you can use.
Re: source for 3/4" tall o2 sensor bungs [Re: geo.] #2645565
04/15/19 11:12 PM
04/15/19 11:12 PM
Minnesota
Minnesota
You guys have some great ideas! I just ordered a set of 8 spark plug anti foulers from rock auto for $2.24 each.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: source for 3/4" tall o2 sensor bungs [Re: Hemi_Joel] #2645620
04/16/19 07:21 AM
04/16/19 07:21 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
I could have just made, and welded spacers to your existing bungs before welding them to the headers, at my work.
69 GTX 68 Road Runner
Re: source for 3/4" tall o2 sensor bungs [Re: Hemi_Joel] #2645624
04/16/19 08:02 AM
04/16/19 08:02 AM
n.c.
geo. Offline
geo.  Offline
n.c.
Thanks to the LX Forum guys, they use 'em to space out their O2 sensors for various reasons.
Re: source for 3/4" tall o2 sensor bungs [Re: geo.] #2646556
04/18/19 06:01 PM
04/18/19 06:01 PM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
BTDT. Just remember when it's time to weld them in, those things are plated. Don't breathe the fumes! Those used to hang on the rack at every parts store and I can't imagine why.
Re: source for 3/4" tall o2 sensor bungs [Re: @#$%&*!] #2646757
04/19/19 10:13 AM
04/19/19 10:13 AM
Plymouth, MI
Blusmbl Online content
Blusmbl  Online Content
Plymouth, MI
At full throttle the depth won't matter as much for accuracy but if you're looking to tune part/light throttle conditions it's actually helpful to have more of the O2 sensor tip in the exhaust stream. There is a reason the bungs have a standard height.
I actually milled the bung depth down on a set of headpipes for my Harley as the closed loop control wasn't very good at light throttle due to poor O2 signal at low exhaust flows.
Re: source for 3/4" tall o2 sensor bungs [Re: Blusmbl] #2646856
04/19/19 02:13 PM
04/19/19 02:13 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
I don't think you want an O2-sensor poke its head straight into the red hot exhaust fumes that close near the head. You'll cook them.
AFR doesn't change at 0 or 2" depth away from the headertube, so to make 'm last I would put them away from direct exhaust fumes.
