Re: 2004 dodge dakota
[Re: buildanother]
#2644745
04/13/19 01:49 PM
04/13/19 01:49 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
I would recommend doing the timing chains, guides and tensioners NOW, once those pieces of plastic guides start falling apart (has nothing to do with oil changes just cheap plastic don't belong in a hot engine) they can cause all kinds of havoc. They usually start going between 100,000 and 150,000 with a rare outlier going farther. Do the water pimp while you got it off. At my shop we charge straight up $750 for the whole job but all my guys have done so many they can do it blind folded now, most shops hear the noise and tell you to get a new engine and most won't even touch the inside of one.
[Re: HotRodDave]
#2644878
04/14/19 12:22 AM
04/14/19 12:22 AM
Posts: 3,688 Alexandria,La.
BigTerry
Alexandria,La.
wow... i sure didnt know that! i will check out prices for timimg set.. thank for the head up on that! my new ride got 157000 on it not sure of the service history .. she runs great I'm hoping she last till I can gather all the parts needed! again thanks!
[Re: BigTerry]
#2646042
04/17/19 12:33 PM
04/17/19 12:33 PM
BigTerry
Alexandria,La.
did a tuneup yesterday check out the plugs ..if i remember how to post a picture.. i found out this truck has a jet performance module .. do i need to open the gap on the spark plugs?? it running great now just wondering...
[Re: BigTerry]
#2646061
04/17/19 01:32 PM
04/17/19 01:32 PM
HotRodDave
Kalispell Mt.
I always run an NGK plug and gap it about .005 bigger than the sticker on the hood says, a bigger gap makes a hotter spark and the individual coil will have no issues firing the bigger gap. Use dielectric grease in the plug boot and make sure both are super clean.
