What piston stop for a big block?
#2636499
03/24/19 04:00 PM
03/24/19 04:00 PM
Posts: 2,254 IL
furious70
IL
What's the best one for an oem head, 9:1 engine?
Re: What piston stop for a big block?
[Re: furious70]
#2636568
03/24/19 06:33 PM
03/24/19 06:33 PM
Posts: 43,095 Bend,OR USA
I made my own on the first one, I knock all the center porcylen and center electrode out of the spark plug and inserted a long 5/16( I think that was the size) bolt with a nut on the cylinder side to lock and hold the bolt into plug body and used it as my first piston stop with the head on. You can buy them from most any tool truck, they are usually brass or bronze mix also which is good one of the ones I've bought had a small hole in the center to relive the pressure when moving the piston up towards TDC, I think it whistle also
[Re: Cab_Burge]
#2636632
03/24/19 08:48 PM
03/24/19 08:48 PM
Yes get one with the hole in the center.
[Re: RapidRobert]
#2636661
03/24/19 09:38 PM
03/24/19 09:38 PM
Posts: 2,254 IL
furious70
IL
I see 14mm and 18mm ones listed but no sae?
[Re: furious70]
#2636712
03/24/19 11:00 PM
03/24/19 11:00 PM
I see 14mm and 18mm ones listed but no sae? What motor are you wanting the SAE one for? What size and thread count do you want? All the American made car I know of use either a 18MM or a 14MM thread spark plug
[Re: Cab_Burge]
#2636767
03/25/19 06:45 AM
03/25/19 06:45 AM
Posts: 2,254 IL
furious70
IL
BB Mopar. A lot of the ones I saw listed on Amazon said small gas engines and chain saws so wasn't sure if I'm missing something.
[Re: furious70]
#2636944
03/25/19 12:28 PM
03/25/19 12:28 PM
Posts: 30,989 Oregon
AndyF
I see 14mm and 18mm ones listed but no sae? Spark plugs went metric back around 1930.
[Re: AndyF]
#2636951
03/25/19 12:54 PM
03/25/19 12:54 PM
Posts: 1,602 westerly, ri. usa
440lebaron
westerly, ri. usa
as I recall spark plugs were invented overseas in England that's why they are metric??
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
[Re: 440lebaron]
#2636998
03/25/19 03:09 PM
03/25/19 03:09 PM
AndyF
as I recall spark plugs were invented overseas in England that's why they are metric?? Not sure where they were invented but Albert Champion was a French guy who had a lot of early commercial success making plugs. I think he went on to be the founder of AC Delco also. Some early Fords use pipe threads for plugs but gradually all the popular stuff moved to metric.
[Re: 440lebaron]
#2637003
03/25/19 03:21 PM
03/25/19 03:21 PM
Posts: 14,491 So. Burlington, Vt.
as I recall spark plugs were invented overseas in England that's why they are metric?? Of course....... I don’t think England was on board with the metric system “back in the day”.
[Re: fast68plymouth]
#2637113
03/25/19 08:13 PM
03/25/19 08:13 PM
as I recall spark plugs were invented overseas in England that's why they are metric?? Of course....... I don’t think England was on board with the metric system “back in the day”. You are correct on that Them dang English and their English standards That is not to say we Americans have never done that type of thing to go against the worlds standards
#2637242
03/26/19 08:09 AM
03/26/19 08:09 AM
Posts: 1,756 London, England
Gavin
London, England
as I recall spark plugs were invented overseas in England that's why they are metric?? Of course....... I don’t think England was on board with the metric system “back in the day”. Hey ...we still aren't Actually, we're kind of schizophrenic - still universally use miles and mph, milk sold in pints (let's not go there...), sometimes use lbs weight....but at school even oldies like me did all my maths, and Engineering degrees in metric, and pretty much everything else is metric too. I'm just about used to deg C in the weather forecast....but I speak deg F too
