Re: Anyone running the Passon Hemi OD 4 speed?
[Re: 70VcodeCoronetRT]
#2636372
03/24/19 12:09 PM
03/24/19 12:09 PM
Posts: 1,567 Ky
jt4406
Ky
I have one in my challenger, really like the difference it made. I replaced a good 18spline with it, and the reduction in highway cruising rpm made my car much more enjoyable. Rpm at 75 mph dropped from 3450 to 2750. Gear ratio spread between the gears feels much better than the factory OD with it's "granny" gear first (ran one of those a while). Other than a being little more "gear noisy" than the 18 spline, it's way better. Hoping this is only due to "break in", though I do have a couple thousand miles on it now. Good gear ratio, speed RPM calculator here: https://www.crawlpedia.com/rpm_gear_calculator.htm
Yeah, it's hopped up to over 160...
#2636488
03/24/19 03:30 PM
03/24/19 03:30 PM
Posts: 4,446 Morristown Tn.
71birdJ68
Morristown Tn.
I have one in my RR. 354 gears and G60x15 tires, 2,500 gives me around 75. If you plan on driving your car any on the Inter State then I'd do it, around town, maybe not. You're not going to any racing with just a three speed, and it's not a slick shift, ie speed shift racing. I have a 528, so I can just torque around town in 3rd gear with no problems. Bottom line, make the choice according to your intended usage.
[Re: topside]
#2636504
03/24/19 04:09 PM
03/24/19 04:09 PM
Posts: 1,145 ontario calif
ns1aar
ontario calif
I have one in my AAR gear ratios work for me but its almost embarrassing noisy and they cant seem to fix it. I may just go back to the original gear set and change the rear end ratio
NS1AAR
[Re: ns1aar]
#2636522
03/24/19 04:37 PM
03/24/19 04:37 PM
Posts: 15,976 Chilliwack B.C. Canada
RUNCHARGER
We installed one n my friend's 71 Cuda with a 572 Hemi and 3.73 gears. It works great, just use 3 gears in the quarter with most setups. I think it's the perfect setup with a stroker, I wouldn't want the 5 speed. It wouldn't work as well with a small engine of course.
Sheldon
[Re: WO23Coronet]
#2636744
03/25/19 12:54 AM
03/25/19 12:54 AM
ns1aar
ontario calif
I tried the Keisler perfect fit 5sp guess what I would have to cut my floor and would still have driveline angle issues. Their solution add spacers between the k-frame and frame rails or cut the torsion bar mount. Ya right on an AAR. Fortunately I got my money back on that one. Next up the Passons OD bolts up fine ratios work well with my 3.91s. Now the catch it sounds like an old truck loosing its bearings. Passons couldn't fix it. The designer couldn't even fix it although he tried harder than Passons This whole project has been years of the car setting My trans has more travel miles than my car has since the resto . Now I have some money in this trans project and no results. Gear vendors might be great but more money. It might be time to cut the losses and go with something the works
NS1AAR
[Re: fastmark]
#2636831
03/25/19 09:21 AM
03/25/19 09:21 AM
Posts: 1,567 Ky
jt4406
Ky
My car has a complete 2.5 inch Accurate Exhaust system with stainless factory style challenger tips. It is quite and comfortable so the gear noise is noticeable, and it isn't as noticeable in 3rd (which is of course straight through). As I previously mentioned maybe it will quieten down with more miles. The hemi box I removed was quieter, but who knows how many thousands of miles it has on it? Just my .02 and experience so far . jess
[Re: RUNCHARGER]
#2636937
03/25/19 12:18 PM
03/25/19 12:18 PM
Posts: 5,788 Hamilton, Ontario Canada
Magnum
Just the fact that that you have a 470 tells me you want more than to just drive around. If gear ratio spread is at all a factor to you l, consider a close ratio T56 Magnum. It has minimum rpm drop between shift and is the best shifting manual transmission out there.
