Re: Painting Valve Covers
[Re: TOMRR]
#2634714
03/20/19 09:14 AM
03/20/19 09:14 AM
Posts: 18,157 Mass
DAYCLONA
Mass
Have to redo my valve covers on my 440,, after sand blasting should I use etching primer ? or clean and just use a good high temp paint.
Tomrr Painting an engine/components I usually put down a coat of etch primer followed by a coat of Single Stage/ straight Enamel, avoid the spraycan crap....
[Re: TJP]
#2635581
03/22/19 01:26 PM
03/22/19 01:26 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Just don't sandblast the inside of the valve covers......... 3X that Make sure all openings are securely sealed as the abrasive and dust gets into everything. I glassbead or sandblast EVERYTHING body or engine/driveline wise inside and out with ZERO issues, you just have to have an OCD attitude about blowing out/cleaning the part(s)/component(s) afterwards
[Re: DAYCLONA]
#2636795
03/25/19 08:25 AM
03/25/19 08:25 AM
Posts: 1,756 London, England
Gavin
London, England
Just don't sandblast the inside of the valve covers......... 3X that Make sure all openings are securely sealed as the abrasive and dust gets into everything. I glassbead or sandblast EVERYTHING body or engine/driveline wise inside and out with ZERO issues, you just have to have an OCD attitude about blowing out/cleaning the part(s)/component(s) afterwards Yes, as long as you have the OCD it will be OK...but really OCD, not just a spray with brake kleen. Sand can get embedded in the metal, or collect under the baffles etc, and several people found that out the hard way when their fresh engine had glass or sand in the oil after breakin. I'm not sure how many people would take enough care. But if you do, should be OK. Stakes are high though.
[Re: Gavin]
#2636853
03/25/19 09:46 AM
03/25/19 09:46 AM
Posts: 3,372 St. Charles, MO
wingman
Uncreative Title
Uncreative Title
St. Charles, MO
I wire brushed mine, cleaned everything white glove clean with brake cleaner, and sprayed a couple coats Plasti-Kote engine paint on the bare metal.
Looked great and held up perfectly for the 10 years I had the car. Simple.
1969 Dodge Coronet Super Bee 383 A4 1970 Plymouth Road Runner 440 FC7 (sold)
