273 2V bogging #2634609
03/19/19 09:41 PM
03/19/19 09:41 PM
Kentucky
dfsmopars Offline OP
Kentucky
After warming up the 273 in a ‘67 Barracuda it wants to bog down real bad with a quick opening of the throttle. Tried moving the timing but no real difference. Tried moving the accelerator pump with no real difference. What does seem to make a difference is to partially close the choke valve. When blipping the throttle there looks like a ton of fuel going in and that little engine sucks a lot of air. This engine sat for many years without starting. Carb is rebuilt. We can’t tell if it is getting too much air, or fuel or both.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring
‘14 Big Horn, Quad Cab, 4x4, 1500
Re: 273 2V bogging [Re: dfsmopars] #2634657
03/20/19 12:42 AM
03/20/19 12:42 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
too much air !
check idle circuts , float level , give it the max pump shot .
set timing to fact spec.
Re: 273 2V bogging [Re: dfsmopars] #2634667
03/20/19 02:05 AM
03/20/19 02:05 AM
RapidRobert Offline
RapidRobert  Offline
Quote
vac leak. spray starting fluid around & see what develops (block the carb with a sheet of thin cardboard etc when spraying to avoid a false positive from fluid getting sucked into the carb throat top). I'd get the RPM up to "medium" or even higher & jerk the throttle & see if it still kicks out a good shot.
Re: 273 2V bogging [Re: RapidRobert] #2634825
03/20/19 01:13 PM
03/20/19 01:13 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Have you checked the vacuum advance?
Re: 273 2V bogging [Re: dfsmopars] #2634875
03/20/19 03:26 PM
03/20/19 03:26 PM
SE Michigan
U
ubercuda Offline
ubercuda  Offline
U
SE Michigan
If the hesitation is worse when the engine is cold the exhaust passageway thru the intake that is there to heat the manifold for better fuel atomization could be blocked with carbon buildup. Had a 69 Barracuda with a 318 that drove me crazy. Finally pulled the intake and the passage was blocked solid. Chipped it clean and solved the bog issue.
Re: 273 2V bogging [Re: ubercuda] #2634924
03/20/19 06:33 PM
03/20/19 06:33 PM
Supercuda Offline
Supercuda  Offline
The OP states "After warming up " probably not a blocked crossover or the choke wouldn't open.
Don't be the exception.
Re: 273 2V bogging [Re: dfsmopars] #2634971
03/20/19 08:43 PM
03/20/19 08:43 PM
Kentucky
Kentucky
Here’s the plan. I’m confident with the mixture screws. Go back to factory timing which is 5* before. Lower float level because I did notice gasket on the top staying wet. Verify the vacuum advance. Check for vacuum leaks. Then see where it from that point.
The intake crossover was stopped up solid which looked like someone had poured block filler in it.
Still have the valves to adjust but on its initial run down the street that little engine has a respectable amount of torque.
Re: 273 2V bogging [Re: dfsmopars] #2635668
03/22/19 06:33 PM
03/22/19 06:33 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
On my first car, a 1969 Plymouth Fury with a 318, the engine would just about die with a stab of the throttle. I rebuilt the carb and noticed the check ball in the bottom of the accelerator pump well was missing. Put a ball from the kit in there, new pump piston and all was well.
Floyd Lippencott IV
Re: 273 2V bogging [Re: mr_340] #2635707
03/22/19 08:59 PM
03/22/19 08:59 PM
RapidRobert Offline
RapidRobert  Offline
I try 15 or even 20 initial (wont hurt you for a test) if it ain't pinging then no harm no foul.
Re: 273 2V bogging [Re: mr_340] #2635860
03/23/19 10:39 AM
03/23/19 10:39 AM
Kentucky
Kentucky
I rebuilt the carb and I was careful to make sure the ball got back in there. But I am going to confirm when I reset the float level.
Rapid we have run the timing up as far as 15 but not 20.
Re: 273 2V bogging [Re: dfsmopars] #2635869
03/23/19 10:56 AM
03/23/19 10:56 AM
RapidRobert Offline
RapidRobert  Offline
If 15 didn't do it then yes the prob is elsewhere.
