Shark tooth repair Q #2634578
03/19/19 08:52 PM
03/19/19 08:52 PM
Ct
W
Wirenut Offline OP
Wirenut  Offline OP
W
Ct
Hi All
Read a post / article here about mixing up a potion of grill material and acetate I believe to make a paste to repair / glue these grills.I have a grill that is cracked that I would like to put in a race car so not show quality .
Question is ... can I use a different style grill for the donor shavings or is there another suitable substitute ? Just looking to stop the cracks from spreading .
Re: Shark tooth repair Q [Re: Wirenut] #2634590
03/19/19 09:06 PM
03/19/19 09:06 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Yes there is a certain type o plastic that needs to be used, but I can't recall the name right now.
Also, stop drill the cracks with a small drill bit before doing the repair work.
Re: Shark tooth repair Q [Re: Neil] #2634594
03/19/19 09:15 PM
03/19/19 09:15 PM
Ct
W
Wirenut Offline OP
Wirenut  Offline OP
W
Ct
Thanks I was thinking the same thing
Re: Shark tooth repair Q [Re: Wirenut] #2634599
03/19/19 09:23 PM
03/19/19 09:23 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
No donor grille plastic needed. With time, patience & some creativity missing bits can be made from scratch.
More details with photos at http://www.1970chargerregistry.com/mboard/index.php?topic=4298.0
Re: Shark tooth repair Q [Re: Alaskan_TA] #2634630
03/19/19 10:42 PM
03/19/19 10:42 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Yes you can use another plastic grille but you need to determine that is the same TYPE of plastic. Most grills are made of ABS or another styrene-based resin, any of which will work fine. You can also by sticks of ABS plastic used for plastic welding. To determine that a plastic is ABS you can do a simple burn test to help identify it. When you light a piece of plastic on fire it will either stay burning like a candle, or self extinguishes when the flame (Bic lighter, match, etc.) is removed from the plastic. You will also notice variables in the smell, the color of the flame, and the color of the smoke. ABS plastic will easily catch fire and will remain burning when the flame is pulled away. Read more here: Plastic Burn test ID
Another old Moparts thread on the subject Plastic repair
Re: Shark tooth repair Q [Re: ScottSmith_Harms] #2639431
03/31/19 11:41 PM
03/31/19 11:41 PM
Oly Wash
racerlall Offline
racerlall  Offline
Oly Wash
have seen old arm rest baces cut up and used to fix 71 cuda grill using a sorting iron like a tig welder of sorts
Re: Shark tooth repair Q [Re: racerlall] #2639441
03/31/19 11:54 PM
03/31/19 11:54 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Yes, most hard plastic armrest bases are ABS plastic.
