Re: SS SPRING SELECTION
[Re: 340Cuda]
#2631805
03/12/19 11:10 AM
03/12/19 11:10 AM
Posts: 20,116 PA.
pittsburghracer
Be careful going to high on the spring rating. I put a set of 002-003 springs on my 1974 Duster that had been lightened and the car handled like crap going down the track wandering around. I took them to a local spring shop where we took them apart and dearched them some. That helped big time and I ended up going 9.80’s with them 30 years ago. With the track prep today they will and do work but if my budget allowed it I would go a different route.
[Re: A/MP]
#2631827
03/12/19 11:36 AM
03/12/19 11:36 AM
Posts: 3,275 West Coast, USA
jbc426
West Coast, USA
After decades of searching for a compliant riding suspension that hooks up hard on the street and track, I ended up running a pair of passenger side 3200lbs SS Springs on both my 3700lbs A-Body & E-Body. Both cars transfer weight to the rear very effectively as the slapper bars simultaneously plant the tires harder than anything else I've tried.
I've heard all the stories and heard this set-up should never work on a Mopar, but it does. Even Robert Tarozzi, the guy who developed the SS Spring specs was impressed with how well the car hooked up.
The cars were spring wrapping the front spring segments with these lighter springs, so I modified some Lakewood slapper bars so they would fit properly on my Mopars. The results are nothing more than amazing.
The cars ride, handle and hook up harder than any other suspension set-up I've tried, including the Caltracs with split mono leafs, which were great on a smooth track, but gave WAY to harsh a ride on the open road. I do use high quality shocks on both cars.
[Re: 7074cuda]
#2634312
03/19/19 08:48 AM
03/19/19 08:48 AM
an8sec70cuda
I used to have the 3400 lb SS springs on my cuda that was 3700 lbs at the time. It hooked good, but the Cal-Tracs were way more consistent. This was running 11.40s on motor w/ a 1.60 sixty foot and 10.60s on nitrous w/ a 1.50 sixty foot. Left front tire would be a foot in the air and the right front barely touching the ground. The Cal-Tracs evened it out.
[Re: an8sec70cuda]
#2634411
03/19/19 01:00 PM
03/19/19 01:00 PM
Posts: 4,651 Wichita
GY3
Wichita
I used to have the 3400 lb SS springs on my cuda that was 3700 lbs at the time. It hooked good, but the Cal-Tracs were way more consistent. This was running 11.40s on motor w/ a 1.60 sixty foot and 10.60s on nitrous w/ a 1.50 sixty foot. Left front tire would be a foot in the air and the right front barely touching the ground. The Cal-Tracs evened it out. Exact same experience here with nearly identical times. Cal-tracs are much more repeatable and consistent.
[Re: Cab_Burge]
#2634423
03/19/19 01:33 PM
03/19/19 01:33 PM
Posts: 20,116 PA.
pittsburghracer
I can’t remember the 60 foot times as it was many many years ago but my 1974 Duster ran 9.82 on Super Stock springs but I sure as heck wouldn’t go that direction today if I was starting fresh
[Re: A/MP]
#2634440
03/19/19 02:08 PM
03/19/19 02:08 PM
Posts: 17,801 S.E. Michigan
ZIPPY
S.E. Michigan
They shouldn't squat. The axle should be forced down. The back of the car will rise up at the same time.
Mine are the 3800lb versions, but having not tried any others except these I don't know if it's better to use a lower rating.
Rich H.
Esse Quam Videri
