Re: Offset head dowels for BB? Minimum radial valve clearance?
[Re: BradH]
#1964518
12/06/15 07:51 PM
12/06/15 07:51 PM
Posts: 4,270 Morrow, OH
markz528
Morrow, OH
Two related questions: 1. Does anyone sell (or can make?) offset cylinder head dowels for BB Mopars? I think for BBs they're only .250" OD, and the smallest offset dowels I see listed anywhere are ~ .310" for SBM / SBC.
2. What is the recommended minimum radial valve clearance (clearance between edge of valve and valve relief in piston)?
Thanks, Brad The offset dowels are easy to make with an offset jig on a surface grinder. My surface grinder is down right now or I could make them for you. I am replacing my old manual one with a hydraulic unit but am rebuilding it before I put it in service. I am a month or two away from finishing it.
67 Coronet 500 9.610 @ 139.20 mph 67 Coronet 500 (street car) 14.82 @ 94 mph 69 GTX (clone) - build in progress......
[Re: BradH]
#1964926
12/07/15 03:06 PM
12/07/15 03:06 PM
Posts: 5,160 Texas
dannysbee
Texas
I was thinking bbc was the same. I have a friend that has made the offset dowl pins. One thing to remember is at some point you have to enlarge the bolt holes also. If I was going for optimum performance I would sonic check the block and cnc the cylinder bores as high as possible along with the offset dowels.
Getting old just means you were smarter than some and luckier than others.
[Re: BradH]
#1964940
12/07/15 03:51 PM
12/07/15 03:51 PM
Posts: 4,205 New York
polyspheric
X2 - with the dowels in place you want the bolts to slip into the head with effort.
Boffin Emeritus
[Re: dannysbee]
#1964993
12/07/15 05:06 PM
12/07/15 05:06 PM
Posts: 43,097 Bend,OR USA
I was thinking bbc was the same. I have a friend that has made the offset dowl pins. One thing to remember is at some point you have to enlarge the bolt holes also. If I was going for optimum performance I would sonic check the block and cnc the cylinder bores as high as possible along with the offset dowels. BB chevy are no where near the same as the ones on our B, RB and gen2 hemi motor, they won't work
[Re: BradH]
#1965130
12/07/15 09:31 PM
12/07/15 09:31 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Brad.. when you do find your off set pins make sure they set down flat on the block without the gasket.. I've been there before when the head didnt
[Re: BradH]
#2647089
04/20/19 03:07 AM
04/20/19 03:07 AM
Posts: 236 upstate, New York
jvcuda
upstate, New York
Thanks, Brad found this in the archives from dec 2015
