transmission breather relocation
#999811
05/25/11 05:53 PM
05/25/11 05:53 PM
Posts: 2,509 Sydney,Australia
tex013
Sydney,Australia
when relocting a trans breather i know some,including Cope Trans,recommend drilling into the main case web. is there any problem with just drilling and fitting a breather/pipe fitting in the extension housing ? i am thinking of putting a 90 degree 1/8NPT fitting here and running a 3/8" breather hose up to the engine bay
Tex
New best ET 10.259@129.65 . New best MPH 130.94 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
Re: transmission breather relocation
[Re: tex013]
#999812
05/25/11 08:19 PM
05/25/11 08:19 PM
dartman366
Mt. Vernon, Ohio
Tex
I originally had mine there and it all over ,,finally put it where it belonged and not even a dribble since. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: dartman366]
#999813
05/25/11 08:44 PM
05/25/11 08:44 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
I have mine there.
I originaly had a -4 line going up to a diff breather and it would still spew fluid out.
I now have a -6 line going up to a Jr dragster catch can mounted on the fire wall.
![](http://i300.photobucket.com/albums/nn35/wildracing/transventcatchcan.jpg)
![](http://i300.photobucket.com/albums/nn35/wildracing/Motor/limter009.jpg)
[Re: IcorkSOAK]
#999816
05/25/11 10:06 PM
05/25/11 10:06 PM
tex013
Sydney,Australia
Bill,Dartman, thanks for the responce. Bill i also will use a small catch can. i am just a little leary of drilling in the web as the trans is not coming apart.i will be using an aluminium plug in the pump. all goes well i will get the trans out this arvo Doc,it drops about 5-10cc out of the bell housing after each pass,but only at the drags not when daily driven Tex PS: C4's have the breather on the extension housing though there is a cast baffle under it
[Re: tex013]
#999818
05/25/11 10:15 PM
05/25/11 10:15 PM
dartman366
Mt. Vernon, Ohio
If done correctly the only thing you would have to take off would be the extention housing,, which if you drilled it then it would have to take it off anyway to clean out the chips,, when you drill the housing your not supposed to break into the internal area of the case, wish I had a pic of what I am talking about, it would be easier to understand.
[Re: dartman366]
#999820
05/25/11 10:54 PM
05/25/11 10:54 PM
WILD BILL
BROOK PARK, OH
If you do decide to use the tail shaft, Remember there is a fluid passage that runs along the top. It feeds fluid to the rear bushing for lubrication.
[Re: rebel]
#999822
05/26/11 10:28 PM
05/26/11 10:28 PM
tex013
Sydney,Australia
thanks for all reply's.bit the bullet and fitted it in the case hope this stops the drips
Tex
