I got my motor running SUNDAY and i checked the converter MONDAY night it gos 5,600 on the trans brake man if it runs as good as it sounds WOW it will be BAD i order a set of wheelie bars to put on the car i think i will need them. Look about 4 months ago i got a MILEDON oil pan and oil pump and lines off a guy here on MOPARTS he said it was ( OK ) will i had a oil leak will guess where it was OH HELL YES THE OIL PAN WILL THANKS MAN but i got it fixed . I am going FRIDAY to see what it will run i will let you all know what it runs. MOPAR OR NO CAR.
