Cost to freshen short block.......................
#998639
05/23/11 09:14 PM
05/23/11 09:14 PM
Thumperdart
State of confusion
Since I just went through my heads, I`m thinking about re-honing the block and throwing in new rings, bearings and gaskets on my 400/470 stroker and was wondering what the average cost is since I havn`t worked in a machine shop for a while. Thankxxx............ ![](/ubbthreads/images/graemlins/beer.gif) EDIT; I mean, bearings,rings gaskets etc. plus the hone job and I`ll put it together. ![](/ubbthreads/images/graemlins/thumbs.gif)
Re: Cost to freshen short block.......................
[Re: Thumperdart]
#998640
05/23/11 09:26 PM
05/23/11 09:26 PM
Posts: 20,698 in a cattle trailer down by th...
Guitar Jones
I just recently had a block done, not a refresh though but taking out what you don't need to buy or have done, like balancing, pistons, block fill and so forth I'd say probably in the neighborhood of $400-$600.
[Re: Thumperdart]
#998643
05/23/11 10:53 PM
05/23/11 10:53 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Id say $300-$500 Dom... Figure main and rods bearings will cost you $175-$200 alone.. Good set of conventional file fit rings... Another $150 or so. Then you may find that the crank might need to be polished out... Good time to have it magna fluxed and check for hair line cracks... So maybe another $50 there. Then if the timing chain is loose.. another $75. The you need all gaskets.. This can cost as little as $60-$80 or if you run the better head gaskets additional $125-$150.. Oil pump should be checked.... Lifters.. springs.. rocker arms.. Need close inspection... You run a roller so the bronze gear needs looked at... I have freshen'd a few race motors for just the cost of bearings and gaskets if all looks good... Good luck...
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: Bob_Coomer]
#998646
05/23/11 11:49 PM
05/23/11 11:49 PM
Posts: 16,934 NC
440Jim
NC
That is a good shopping list. But I didn't see the cost of a hone with torque plate and that could be $150-$250. The crank magnaflux is worth doing, and you could do the rods too if you have any concerns.
[Re: 440Jim]
#998647
05/24/11 12:18 AM
05/24/11 12:18 AM
Thumperdart
State of confusion
Jason Pettis quoted me $200.00 for a hone w/a torque plate plus I`ll need cam bearings installed since I don`t have the tool.
