Plasma cutter - what are you using? #998500
05/23/11 05:53 PM
05/23/11 05:53 PM
VA
AtomicDog Offline OP
VA
I'm looking to purchase a plasma cutter. I would like to be able to cut anything from sheet metal up to 5/8" steel plate without issue. I'd like to find a unit that runs on 220V single phase power, is highly reliable and won't break the bank when purchasing consumables (tips, etc.).
Does anyone here use a plasma cutter for these purposes? If so, what are you using and how happy are you with your choice?
Re: Plasma cutter - what are you using? [Re: AtomicDog] #998501
05/23/11 07:33 PM
05/23/11 07:33 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
I have a Thermal Dynamics unit very happy with it.
It has auto volt sensor so it will run on 110 or 220 just buy changing the plug.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Plasma cutter - what are you using? [Re: dusturbd340W5] #998502
05/23/11 07:51 PM
05/23/11 07:51 PM
kentucky
superbyrd Offline
superbyrd  Offline
kentucky
hypertherm. love it.
Re: Plasma cutter - what are you using? [Re: superbyrd] #998503
05/23/11 07:56 PM
05/23/11 07:56 PM
Alaska
73rrak Offline
73rrak  Offline
Alaska
Hypertherm here also 10 or 12 years old... great machine
Re: Plasma cutter - what are you using? [Re: dusturbd340W5] #998504
05/23/11 08:00 PM
05/23/11 08:00 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I am still using my Esab plasma that I bought used 15 years ago. It's huge compared to to todays units but it has never broke down.
Re: Plasma cutter - what are you using? [Re: Challenger 1] #998505
05/23/11 08:48 PM
05/23/11 08:48 PM
Tustin, CA
P
pishta Offline
pishta  Offline
P
Tustin, CA
8 buck garage sale jig saw! (sorry, I would love a plasma cutter too, they are amazing) along with a waterjet.
12 Grand Caravan
06 T&C
02 T&C
96 Breeze
65 Barracuda "S"
Re: Plasma cutter - what are you using? [Re: pishta] #998506
05/23/11 10:36 PM
05/23/11 10:36 PM
Kissimmee Fl.
Kissimmee Fl.
dont know about the others but my Thermal Dynamics is made in the U.S.A
Re: Plasma cutter - what are you using? [Re: dusturbd340W5] #998507
05/23/11 10:41 PM
05/23/11 10:41 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
5/8 plate is gonna need a serious plasma cutter.
I can't see any 110 machine doing that. Gonna be a 220 volt with 50 amp input minimum is my guess.
Thermal Dynamics are nice. I have a small miller which is OK. Wish mine had more amperage.
Re: Plasma cutter - what are you using? [Re: RobX4406] #998508
05/23/11 11:59 PM
05/23/11 11:59 PM
kentucky
superbyrd Offline
superbyrd  Offline
kentucky
hypertherm are built completely in hanover,NH,usa. and the employees own the company. the thermal dynamics torch/leads are made in mexico,and the power inverters are made in the USA,for them,....in NH.......so price shop wisely,they both sell great products.
Re: Plasma cutter - what are you using? [Re: AtomicDog] #998509
05/24/11 12:49 AM
05/24/11 12:49 AM
Jacksonville Florida
elitecustombody Offline
Cebora 3100 here , no way it will cut 5/8" ,but all in all I'm happy, it will cut 3/8".I bought it to cut sheetmetal and it cuts awesome!
FYI, usually you can find consumables dirt cheap on ebay in bulk,
Re: Plasma cutter - what are you using? [Re: elitecustombody] #998510
05/24/11 07:48 AM
05/24/11 07:48 AM
MrNormTA Offline
MrNormTA  Offline
Hypotherm 1250 for me. Mine will cut upto 1 1/2 plate steel! It was the largest one made at the time when I bought it. Just make sure you have a good dry air source.
Re: Plasma cutter - what are you using? [Re: MrNormTA] #998511
05/24/11 03:43 PM
05/24/11 03:43 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Price your consumeables, I have an Esab 35 amp, the comsumables cost 120.00 for a set of 5, the comparable Hypertherm is 45.00. Tim
Re: Plasma cutter - what are you using? [Re: astjp2] #998512
05/25/11 11:32 PM
05/25/11 11:32 PM
VA
VA
Thanks for all of the feedback. Sounds like Hypertherm and Thermal Dynamics are the most popular choices. Anyone else care to chime in?
Re: Plasma cutter - what are you using? [Re: AtomicDog] #998513
05/26/11 12:25 AM
05/26/11 12:25 AM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
I've had a USAweld Microcut 301 for about 6 months and have not 1 complaint, works great. Made in Italy. Only cuts upto 3/8ths though.
http://www.usaweld.com/SearchResults.asp?Cat=47
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Plasma cutter - what are you using? [Re: HemiRick] #998514
05/26/11 02:24 AM
05/26/11 02:24 AM
MI
68shifter Offline
68shifter  Offline
MI
Have a hypertherm that will do 1" and is 220. Works great, bought used off craigslist for $600 with a bunch of consumables. Very nice unit, easy to move around about the size of two big boot boxes or so.
Also have a lincoln that will do well over 1". Consumables are pricey but man it works nice even down to little decorative thin stuff.
I would just say stay away from ones with swivel heads on the torch that do all sorts of stuff. I had one a couple years ago, I think it was a thermal dynamics, and the head was a pain on long straight cuts because it wanted to pivot. I would still have it though if some a-hole didn't rob me!
You'll like any of them though really, they are so handy.
68' Barracuda (4 speed) 64' Savoy (4 speed) 65' Satellite (girl tranny)
Re: Plasma cutter - what are you using? [Re: 68shifter] #998515
05/26/11 09:19 AM
05/26/11 09:19 AM
East Brunswick, NJ
finadk Offline
finadk  Offline
East Brunswick, NJ
Anyone with the Thermal Dynamics using the Drag-gun unit? I have seen a few used ones near me at a decent price.
Scott
Scott 1956 Dodge Custom Royal Lancer (408 Stroker, 4 Wheel Disc Brakes, Rack & Pinion, 6 speed) 2002 Dodge Ram 1500 Quad Cab 1976 Corvette
Re: Plasma cutter - what are you using? [Re: AtomicDog] #998516
05/26/11 04:47 PM
05/26/11 04:47 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I've got a Thermo Dynamics Pak10? thats 20? years old. Works fine. It'll do 1/2" alum, which is like 3/4"? steel. However, as mentioned, the consumables, tips, cups, etc are the the real cost of useage, kinda like Kodak giving you a free camera if you bought their film days.
Re: Plasma cutter - what are you using? [Re: Challenger 1] #998517
05/28/11 09:24 PM
05/28/11 09:24 PM
WI
RestoRick Offline
RestoRick  Offline
WI
Chally1... your pic cracks me up!!... do you bask in that hot tub while looking over your cool tools?
And for the topic- I have a small HTP one that's super portable and will do up to 3/8"... plenty for any car stuff I encounter.
model 380 (looks like the newer model is micro 400) I've had it for just over 10 yrs. and has worked flawlessly. Consumables are reasonable too.
Re: Plasma cutter - what are you using? [Re: RestoRick] #998518
05/28/11 11:28 PM
05/28/11 11:28 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
I also have a 15 year old Esab that works well. Buy the largest unit you can afford.
Re: Plasma cutter - what are you using? [Re: DoctorDiff] #998519
05/28/11 11:43 PM
05/28/11 11:43 PM
Ohio, USA
Donny Offline
Donny  Offline
Ohio, USA
