Re: 505" six pack engine WOT "bog"
[Re: MoparJunkie]
#998473
05/24/11 09:45 AM
05/24/11 09:45 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
64's on center haven't checked outboards. 32 total timing...12 initial 20 in distributor. 4 speed... using newer replacement carbs... LM2 coming wednesday...
I'd try 36* in full at 2000rpm... That's where I have mine.
[Re: MoparJunkie]
#998475
05/24/11 10:38 AM
05/24/11 10:38 AM
Posts: 13,402 Marion, South Carolina [><]
an8sec70cuda
I had the same problem w/ my dad's 440 six pack in his road runner. I called up sixpackgut and took his advice...50 cc accel. pump and 35 squirter on the center carb. No more bog. edit...this was on a smaller (448") and milder motor though.
[Re: Streetwize]
#998478
05/24/11 11:52 AM
05/24/11 11:52 AM
Posts: 1,138 Home of the Bluegrass
MoparJunkie
Is there any modifying I need to do to put a 50cc accel. pump on? And where can I get the 35 squirter?
"It takes a Mopar to catch a Mopar” 1971 Roadrunner FJ6 Sassy Grass 505"RB, 18 spline 4 speed, and Dana 60 with 3.54 2022 Hellcat Charger Widebody Redeye Jailbreak: Hellraisin with 8 speed auto
[Re: MoparJunkie]
#998479
05/24/11 11:56 AM
05/24/11 11:56 AM
an8sec70cuda
Nope. Just get the 50 cc pump kit from Holley and bolt it on. Careful changing the stud in the baseplate...they tend to break. The pump kit and the squirter can probably be bought from your local parts store that carries Holley parts. There are a couple stores around here that have some Holley parts in stock. Jets, squirters, and 50 cc pump kits are usually on the shelf. Or you could always order from Jegs, Doug Herbert, or Summit.
[Re: an8sec70cuda]
#998480
05/24/11 12:27 PM
05/24/11 12:27 PM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
I am not going any further with this I am out.
JAKES AUTOMOTIVE
[Re: JAKE68]
#998481
05/24/11 12:33 PM
05/24/11 12:33 PM
MoparJunkie
I have the springs also Jake... Just trying to compile info and parts for tuning this weekend...
[Re: MoparJunkie]
#998482
05/24/11 02:27 PM
05/24/11 02:27 PM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
Start with basic engine tuning:
1.) Get your timing issue corrected first. This is critical! Likely needs 16 to 18 initial and 32 to 35 total. You need to shorten up your mechanical advance. 2.) Check for vacuum leaks and check/set your float levels correctly. This is critical! If you're running them straight out of the box, they are unlikely to be set right. The outboards like the level a bit higher than the center.
3.) Adjust the center carb first with the outboards disconnected and wired shut(I've read horror stories about them opening wide when the linkage is disconnected and the motor blowing. Get it starting, running and idling clean.
If you do end up using the 50cc pump, and larger than a #32 discharge nozzle, you will also need the high-flow discharge nozzle screw.
Adjust the tip-in of the outboards, so there is no bog during the transition to wide open...it just wants more fuel as they start to open and begin flowing fuel through the boosters. This is why float level, spring rate and accelerator pump disharge size etc(center carb) are so important.
Once they are all open and flowing through the boosters, then there is the all important wide open throttle jetting.
I run the mechanical secondary carbs, so i'm no vacuum carb tuning expert, BUT there is some good advice in this thread and also a great post on tuning them somewhere on this board. It's a good starting point, but with the extra cubes and bigger cam you will have to fine tune with your LM2. Cab_burge, for one, has given me excellent advice and is extremely experienced and knowlegable about about both types of carbs. He is amoung a well-represented group of talented Mopar sixpack tuner/ engine builders here, like Steetwise and many others that I appologize to for not naming. They know who they are, but I do have CRS and cant remember them all.
There is more than one way to skin a cat. Getting rid of the bog and having great performance without over-fueling is a balancing act that, with patience and perseverence, you can master. Your LM2 will serve you well in your quest.
Is your manifold crossover blocked? Consider some Promax upgrades on your carbs such as metering blocks and baseplates to ease tuning with your LM2.
[Re: jbc426]
#998483
05/24/11 02:58 PM
05/24/11 02:58 PM
Posts: 9,892 Weddington, N.C.
Streetwize
Weddington, N.C.
You might want to PM member PHJ426, he bought my old 508" RB motor and put a sixpak set up on it, sounds like he's got it pretty well dialed in There's nothing really magic about a 35 shooter, but there are 2 different types, I prefer the rifle barrel shooters because they "aim" the shot right at the booster so it tends to break-up or "atomize" the shot a bit better than the "nostril" type. anything that helps distribute that big slug of gas to all the cylinders is best for your bore life. With a 50cc pump if a 35 works well I at least go ahead and try a smaller 31, if I can't detect any difference I run the smaller one, the less raw gas you have to shove down into the bores the better in terms of ring life
[Re: Streetwize]
#998484
05/24/11 03:42 PM
05/24/11 03:42 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
The same amount of fuel will come out of the squirter no matter what size squirter is on the carb. it will either shoot a bigger/shorter duration shot or a smaller/longer shot of gas. but a smaller shooter will still be squirting as rpms run up reducing load up at off idle
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
