trying to debug a ground problem.
running a new trailer harness.
hooking just the park lite wires up and grounding the trailer light assemblys the park lites work normal.
hooking in the stop/turn lite wires, the park lights will now operate with no ground! apparently grounding back threw the stop/turn wires?
and the turn signal flashes alternatly from truck to trailer instead of at the same time.
the large plug adapter checks out ok.
the trailer wiring is new.
seems to be factory installed hitch and trailer plug wiring with no signs of melting or butchering by previous owner.
the stop/turn circut is apparently shorted into the park lite circut ?
any suggestion of a test to narrow the problem area?
