Page 11 of 14 1 2 9 10 11 12 13 14
Re: My 68 Hemi Charger Project -a little different [Re: Keith Black®] #997975
05/31/11 09:21 AM
05/31/11 09:21 AM
QLD Australia
Keith Black® Offline OP
QLD Australia
picture of headers from side:
Re: My 68 Hemi Charger Project -a little different [Re: Keith Black®] #997976
05/31/11 09:24 AM
05/31/11 09:24 AM
QLD Australia
QLD Australia
good ground clearance, headers are tight. very happy with the headers despite the modifications required to fit & the ceramic coating is a bit "B" grade but I am jet-hot-coating the whole system on final assembly anyway
Re: My 68 Hemi Charger Project -a little different [Re: Keith Black®] #997977
05/31/11 09:28 AM
05/31/11 09:28 AM
QLD Australia
QLD Australia
to the mid-section.
made our own x-pipe and all pipes for that matter, using mandrel bends, collectors are 4 inch down to 3 inch into Magnaflow mufflers.
There will be 4 mufflers....
Re: My 68 Hemi Charger Project -a little different [Re: Keith Black®] #997978
05/31/11 09:30 AM
05/31/11 09:30 AM
QLD Australia
QLD Australia
x-pipe:
Re: My 68 Hemi Charger Project -a little different [Re: Keith Black®] #997979
05/31/11 09:31 AM
05/31/11 09:31 AM
QLD Australia
QLD Australia
another, x-pipe, front part of system:
Re: My 68 Hemi Charger Project -a little different [Re: Keith Black®] #997980
05/31/11 09:34 AM
05/31/11 09:34 AM
QLD Australia
QLD Australia
these are the v-clamps i used. they're a great part. stainless v-rings welded to pipe & clamped with an inverted v-clamp. this meant the system could be constructed in sections. easier later if i need to replace any individual part; .. big pipes
Re: My 68 Hemi Charger Project -a little different [Re: Keith Black®] #997981
05/31/11 09:36 AM
05/31/11 09:36 AM
QLD Australia
QLD Australia
....& toward the rear:
Re: My 68 Hemi Charger Project -a little different [Re: Keith Black®] #997982
05/31/11 09:42 AM
05/31/11 09:42 AM
QLD Australia
QLD Australia
fabricating the exhaust system was a major.
a HUGE job.
the TTI's are great, but given the tight clearances it's hard to expect they will fit out of the box. then getting 3 inch pipes down the car, with enough ground clearance considering the car is lowered 2 inches (a "true" 2in), was a challenge.
all before trying to get 3inch pipes over the diff, which the next pic;s show how we did it. HUGE job, but it turned out great...
(still many more pics to come..!)
Re: My 68 Hemi Charger Project -a little different [Re: Keith Black®] #997983
05/31/11 04:15 PM
05/31/11 04:15 PM
ohio
70shaker6pk Offline
super gas
70shaker6pk  Offline
super gas
ohio
Very nice, great work!
Re: My 68 Hemi Charger Project -a little different [Re: 70shaker6pk] #997984
06/01/11 09:16 AM
06/01/11 09:16 AM
QLD Australia
QLD Australia
thanks Pete. been hard work, years and $$.
Re: My 68 Hemi Charger Project -a little different [Re: Keith Black®] #997985
06/01/11 09:17 AM
06/01/11 09:17 AM
QLD Australia
QLD Australia
Now, getting 3 inch pipes (mandrel bends) over the diff meant making a new axle-hump. Just simply not enough room.
Re: My 68 Hemi Charger Project -a little different [Re: Keith Black®] #997986
06/01/11 09:19 AM
06/01/11 09:19 AM
QLD Australia
QLD Australia
So we made sections with the same v-clamps:
Note: all pipes will be jet-hot-coated (ceramic) at final assembly.
Re: My 68 Hemi Charger Project -a little different [Re: Keith Black®] #997987
06/01/11 09:21 AM
06/01/11 09:21 AM
QLD Australia
QLD Australia
with the new axle-hump we fabricated enough room to put extra's underneath, such as fuel tank vent charcoal canister and output in-line filter (more later). New hump retains provisions for rear seat-belt anchor too:
Re: My 68 Hemi Charger Project -a little different [Re: Keith Black®] #997988
06/01/11 09:22 AM
06/01/11 09:22 AM
QLD Australia
QLD Australia
with the rear seat frame installed (slight mods to clear widened wheel wells): looks a bit scruffy but only a trial fit.:
Re: My 68 Hemi Charger Project -a little different [Re: Keith Black®] #997989
06/01/11 09:24 AM
06/01/11 09:24 AM
QLD Australia
QLD Australia
looking forward where the mid-section ends and goes over the diff:
Re: My 68 Hemi Charger Project -a little different [Re: Keith Black®] #997990
06/01/11 09:25 AM
06/01/11 09:25 AM
QLD Australia
QLD Australia
front, from rear axle:
Re: My 68 Hemi Charger Project -a little different [Re: Keith Black®] #997991
06/01/11 09:29 AM
06/01/11 09:29 AM
QLD Australia
QLD Australia
with the extra space created by removing the leaf springs, and going for the look I wanted, I put the second muffler (3 inch magnaflows), up into the lower quarter, pic 1:
Re: My 68 Hemi Charger Project -a little different [Re: Keith Black®] #997992
06/01/11 09:30 AM
06/01/11 09:30 AM
QLD Australia
QLD Australia
they fit really well,:
Re: My 68 Hemi Charger Project -a little different [Re: Keith Black®] #997993
06/01/11 09:31 AM
06/01/11 09:31 AM
QLD Australia
QLD Australia
..almost designed for 'em:
Re: My 68 Hemi Charger Project -a little different [Re: Keith Black®] #997994
06/01/11 09:32 AM
06/01/11 09:32 AM
QLD Australia
QLD Australia
whole system installed:
