Re: Warped trans steels, what caused this ????? PICS [Re: JohnRR] #995573
05/22/11 11:17 AM
05/22/11 11:17 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
This problem is fairly new to the vehicle, we've owned it since new.
Don't be the exception.
Re: Warped trans steels, what caused this ????? PICS [Re: Supercuda] #995574
05/22/11 11:22 AM
05/22/11 11:22 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Not sure what line or where the check ball is on that year , follow the lines till you find the rubber line in the picture above , that has the check ball in it .
Re: Warped trans steels, what caused this ????? PICS [Re: Supercuda] #995575
05/22/11 07:37 PM
05/22/11 07:37 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Hmm, this may explain my wife's 05 Ram's trans. Take it a bit to get going when you put it in gear. Bet the check valve is stuck open letting the converter drain back. So, where does one get the "good" check valve?
Although the factory calls it a converter check valve it's actually a radiator cooler drainback valve, nothing can prevent the converter from draining back...with or without the check valve.
The popular opinion is that there is no "good" check valve, they're all prone to clogging with debris from the converter clutch and causing the damage in the OP. Best to replace the check valve hose with a regular hose with no valve and make the first start of the day in Neutral to refill the converter.
Better yet, install a filter in the cooler feed line.
Re: Warped trans steels, what caused this ????? PICS [Re: John_Kunkel] #995576
05/23/11 07:41 PM
05/23/11 07:41 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
So. I go to my favorite online parts store, RockAuto, and I cannot find this hose listed. Anyone got any suggestions for a check vale free hose, or at least the threads at these fittings so I can install a good filter?
Re: Warped trans steels, what caused this ????? PICS [Re: Supercuda] #995577
05/24/11 08:28 AM
05/24/11 08:28 AM
chatham, Ilinois
fox Offline
super street
fox  Offline
super street
chatham, Ilinois
On the dodge with Cummins all we do is run a 2" drywall screw into the ball and it will pull right out. Then reuse the hose!!!
