Turbo 383 would this work?
#995458
05/19/11 09:32 AM
05/19/11 09:32 AM
Posts: 4,503 NJ
440challenger
NJ
Id like to plan my project turbo 383. I was wondering what would be a good single turbo for a mild 383 . I have a set of block hugger headers i will use, and i can fab pretty much all the piping/exhaust. I was wondering if this kit would be worth the money if the turbo is big enough? http://www.fastwayracer.com/p796/Universal-GT35-T4-Turbo-Kit/product_info.html
Re: Turbo 383 would this work?
[Re: 440challenger]
#995459
05/19/11 10:04 AM
05/19/11 10:04 AM
Posts: 2,255 IL
furious70
IL
nope, not even close, that's a small guy. For a single on a 383 you want to be looking at something bigger than a T70, a 72 or 76 is pretty common. Depending on how much HP you want to make and your desired rpm range a T6 .96 a/r turbine housing for a responsive street car or a T6 1.23-1.32 a/r housing for more HP/higher rpm. You'll see the Borg Warner s400 series mentioned as well as the old garrett TV75* and TV81/83 series mentioned as you search for info.
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: Fury Fan]
#995461
05/21/11 02:09 PM
05/21/11 02:09 PM
Posts: 66 Reno, NV
Wilde Racing
Reno, NV
I disagree. That turbo will work fine. My turbo specs are almost identical. One small think to keep in mind..... You'll need TWO of them to feed a 383....
[Re: Wilde Racing]
#995462
05/22/11 01:29 AM
05/22/11 01:29 AM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
He specified that it was a single turbo build. In pars the selected turbo would work.
Running just one would be a foolhardy venture at best.
