Page 1 of 3 1 2 3
Just for fun...what will it run? UPDATE!!! Results!!! #994126
05/17/11 11:59 AM
05/17/11 11:59 AM
Beavercreek, Ohio
OA5599 Offline OP
OA5599  Offline OP
Beavercreek, Ohio
Taking to the track for the first time this Friday. Have no idea what to expect, but is WAY more than my dad or I have ever experienced from a little street driving, and we still haven't dipped into the secondaries. It ran low 13s/very high 12s with the low compression 340 before. Probably going to take it easy and shift at 5000-5500 this weekend since it's a new motor.
69 Cuda. 3500 lbs with driver.
418 stroker 10.3:1 comp
Fully CNC'd Eddy Heads from Hughes.
Ported Airgap intake.
248/252 .600/.610 solid cam
Holley 750 modded to flow 910 CFM
MSD E-Curve dist with 6-AL
TTI torque stepped headers w/ Ultra Flo mufflers
3:91 727 Tight 10" converter.
M/T drag radials 275/50/15.
Stock suspension.
Very little tuning to dial it in as we just fired it Sunday for the first time. Don't strain your brain over it, just looking for ballpark. I'll update after this weekend.
Mid/low 12s? High 11s?
Thanks to all who have helped us get this far.
Re: Just for fun...what will it run? [Re: OA5599] #994127
05/17/11 12:13 PM
05/17/11 12:13 PM
Ma
Voluster Offline
Voluster  Offline
Ma
I ran 10.95 at 121 with a 1.56 60ft a couple weeks ago.
I have a little less compression and more carb but pretty close combo
My chassis also seems to be working well
My conveter is more of a nitrous conveter also
I would figure you should be low 11/s maybe high 10's
Re: Just for fun...what will it run? [Re: Voluster] #994128
05/17/11 12:18 PM
05/17/11 12:18 PM
fullmetaljacket Offline
10.65-10.70's.
Re: Just for fun...what will it run? [Re: fullmetaljacket] #994129
05/17/11 12:20 PM
05/17/11 12:20 PM
tboomer Online work
tboomer  Online Work
11.20s-11.30s first time out...
Re: Just for fun...what will it run? [Re: Voluster] #994130
05/17/11 12:25 PM
05/17/11 12:25 PM
No. cal., sacramento usa
speedy383 Offline
speedy383  Offline
Just last week a friend had a very similar combo out. With only 1.80 sixty (traction issues)went 11.89.You should go low twelves on your easy runs and eventually high tens low elevens when sorted out.
Re: Just for fun...what will it run? [Re: speedy383] #994131
05/17/11 01:20 PM
05/17/11 01:20 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
First time out 11.30's - 11.60's. Once dailed in and tuned well mid to high 10's are within reach. Good luck , Ron
Re: Just for fun...what will it run? [Re: OA5599] #994132
05/17/11 05:33 PM
05/17/11 05:33 PM
Guitar Jones Offline
Car is pretty heavy. If that weight is accurate and the converter is on 11.40 - 11.50. Tune it up and 11.20 - 11.30 is within range. I think you'd be hard pressed to get 10's out of the combo the way it sits. You don't have much for a converter, gear or traction so you'll be limited. You also didn't say if this will be full exhaust and what size or open headers. In fact if it's through a full exhaust 11.70 is probably going to be the best you can expect.
Re: Just for fun...what will it run? [Re: OA5599] #994133
05/17/11 05:41 PM
05/17/11 05:41 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
11.30s if it hooks up.
Re: Just for fun...what will it run? [Re: OA5599] #994134
05/17/11 05:43 PM
05/17/11 05:43 PM
Coolville, Ohio
Lew Offline
Lew  Offline
Coolville, Ohio
Stock suspension.
I took this car for a drive last nite, just had to blip the secondaries in 1st &2nd, all i can say is (O!! M!! G!!)
Re: Just for fun...what will it run? [Re: OA5599] #994135
05/17/11 06:32 PM
05/17/11 06:32 PM
MR_P_BODY Offline
MR_P_BODY  Offline
It should run 11.60
Re: Just for fun...what will it run? [Re: MR_P_BODY] #994136
05/17/11 06:33 PM
05/17/11 06:33 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
if it dont run a high 10 or low 11 somethings wrong!
Re: Just for fun...what will it run? [Re: Guitar Jones] #994137
05/17/11 06:44 PM
05/17/11 06:44 PM
Beavercreek, Ohio
OA5599 Offline OP
OA5599  Offline OP
Beavercreek, Ohio
I am running TTI headers and full 3" exhaust with an H-pipe Ultra Flo mufflers. Do you think that free flowing exhaust would slow me down by 4 tenths?
Re: Just for fun...what will it run? [Re: OA5599] #994138
05/17/11 07:28 PM
05/17/11 07:28 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Id say 11.70,s if the vert isnt To tight and the suspension works. You stated Tight vert, do you know what its rated at.
That stock untested suspension with the new combo may keep it in the 12.20 range for starters.
Re: Just for fun...what will it run? [Re: OA5599] #994139
05/17/11 07:38 PM
05/17/11 07:38 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
11.70-ish, but why is it so heavy?? Not a lot of gear, either but your torque should make up for that.
Weight transfer is key with a big torque motor in order for it to ET.
Combo sounds like it should make about 500-520, should push you to right at high 1-teens or so.
I have a loose 10" T/A that I might trade ya, I think it would work better for your heavier lower compression combo....mine on the other hand (12:1, 550+ horse/2900 pounds/85" WB/4.56) might be a bit tamer off the line with a tighter vert
For 1/8th mile ET bracket racing I figure I might just launch in second and not even have to shift for the whole 660', It wouldn't be as quick.....but it'd sure be quick enough in a first leave situation and be consistent as all get-out laugh:
WIZE
In Car:
Re: Just for fun...what will it run? [Re: Streetwize] #994140
05/17/11 08:09 PM
05/17/11 08:09 PM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
You should run mid 11s easily! I think once dialed your combo is probably a 10.9 second combo.
Re: Just for fun...what will it run? [Re: viperblue72] #994141
05/17/11 10:33 PM
05/17/11 10:33 PM
Beavercreek, Ohio
OA5599 Offline OP
OA5599  Offline OP
Beavercreek, Ohio
Do you think running open exhaust would make much of a difference? @Wise: curious to see how this converter works first. Car sees 95% street duty, so I hate to go too loose with it. But I might consider that down the road. Hughes builds this exact motor fairly often, and with the port work they said 550+ HP and 500+ ft lbs.
Re: Just for fun...what will it run? [Re: OA5599] #994142
05/17/11 10:36 PM
05/17/11 10:36 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
run it open pipes and 18 inch long collecter extentions
try jetting up and timming too
1.39 9.85 - 137 mph
Re: Just for fun...what will it run? [Re: Ari440] #994143
05/17/11 11:05 PM
05/17/11 11:05 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
I don't get it.....I guess
That car should run mid 10's with ease. Had a W2 headed 378 with a mild port job that ran 10.68 20 years ago at 3400 lbs. You should have the torque to handle the gear and converter sense it is a 4.00" stroke. I ran a 4.10 gear with a 4400 TA 8" converter.
Leon
Re: Just for fun...what will it run? [Re: OA5599] #994144
05/17/11 11:33 PM
05/17/11 11:33 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
If your going to take it easy and shift at 5000 12.90,s If your going to shift at 5500 12.50,s
Re: Just for fun...what will it run? [Re: Sport440] #994145
05/18/11 12:06 AM
05/18/11 12:06 AM
Bama
Randy.. Offline
Randy..  Offline
Bama
if it don't go 10.90s i would sell it, my old dart all steel hyd flat tappet cam and stock heads on a .030 over 318 with a 150 shot would go that and you got a LOT more motor than i did, even with the spray.
Page 1 of 3 1 2 3
