Re: Just for fun...what will it run?
[Re: OA5599]
#994146
05/18/11 01:53 AM
05/18/11 01:53 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
Car is pretty heavy. If that weight is accurate and the converter is on 11.40 - 11.50. Tune it up and 11.20 - 11.30 is within range. I think you'd be hard pressed to get 10's out of the combo the way it sits. You don't have much for a converter, gear or traction so you'll be limited. You also didn't say if this will be full exhaust and what size or open headers. In fact if it's through a full exhaust 11.70 is probably going to be the best you can expect.
I am running TTI headers and full 3" exhaust with an H-pipe Ultra Flo mufflers. Do you think that free flowing exhaust would slow me down by 4 tenths?
A 3" exh system with Ultra-Flow mufflers and a H-pipe slow you down 4-tenths ? No way that system will slow you down 4 tenths. If the pipes are mandrel bent I say a tenth at the most and that only because its an H and not an X pipe. Ron
[Re: OA5599]
#994148
05/18/11 01:25 PM
05/18/11 01:25 PM
Posts: 2,141 junction city oregon
viperblue72
I think you are going to be pleasantly surprised. Even with tight converter and full exhaust the only way you're gonna run 11.8 is if you get absolutely no traction. I ran a combo just like yours with full exhaust 3k converter in all steel duster with cage. Only difference is I had a 248@050 solid roller. Eventually got down to 11.0s.@122 and that was with a lusy 1.65 sixty foot.
[Re: fishy340]
#994149
05/18/11 01:36 PM
05/18/11 01:36 PM
Posts: 550 Ma
Voluster
Ma
if it dont run a high 10 or low 11 somethings wrong!
x2
[Re: fishy340]
#994150
05/18/11 04:45 PM
05/18/11 04:45 PM
Posts: 316 Coolville, Ohio
Lew
Coolville, Ohio
The tuner will have a lot to do with it i'm sure, i'm no Austin Coil by no means!
[Re: Lew]
#994151
05/18/11 05:09 PM
05/18/11 05:09 PM
Posts: 11,713 Portage,michigan
B3422W5
Portage,michigan
My guess is somewhere between 11.80-12 flat initially.
I had a pretty similar combo years ago in my duster( which at that time with me in in was 3450 pounds( bench seat interior, all steel and a 300 pound driver)cage, etc, etc.
Same headers, different muffs, 248/258 crane cam( way to little), airgap, 727, 4.10 gears, 3500 10 inch convertor, several different carbs, a little more compression, and similar eddies( mine maxed at 275 on the intakes, so likely not quite as good) the car went best of 11.69 at that time, with a lot of fiddling around with it.
I went with 8 inch convertor, fully ported heads, 260/266 flat cam, changed intakes, and raised compression,( 12-1) hair less weight and picked up a whole second the following year. Those saying you are going to run 10's with your current combo will soon see it wont, but you have a nice deal there, good luck. Should pull hard.
With that cam and compression, and other factors, hook, convertor, etc, etc, i suspect about what i sad above at somewhere around 113- 114 mph...
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: B3422W5]
#994152
05/18/11 05:54 PM
05/18/11 05:54 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
Hmmmm....
My heads only flowed 265 and 180. Nothin killer there. Only 3.58 stroke so I had to turn it 8,000. You have a 4.00" stroke you can turn it considerably less. Your cam is close to what I had. Those eddies should be pretty good. Compression is not everything in my opinion. Flame travel is just as important. Your converter may be a power eating pig. If not I stand by the numbers I posted earlier. Mid 10's.
Leon
[Re: OA5599]
#994154
05/18/11 07:18 PM
05/18/11 07:18 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Is the plan to really only short shift it around 5000 or so, like stated in your first post. If so that will handicap the ET,s All you guys saying 10.5,s, you saw that shift point didnt you. You couldnt have IMO
[Re: Sport440]
#994156
05/18/11 07:35 PM
05/18/11 07:35 PM
B3422W5
Portage,michigan
Is the plan to really to only short shift it around 5000 or so, like stated in your first post. If so that will handicap the ET,s
All you guys saying 10.5,s saw that shift point didnt you. You couldnt have IMO
Your right, i take back my 11.80-12.00 thought, with that low of a shift point likely mid 12's
Seriously, though..i think that car , if its 3500 pounds, once sorted out extremely well could go mid 11's as it is, but high 11's at the point he is going to start at. Takes a lot going on to get in the 10's, and with a not optimal convertor, gears, and a small cam( 4 inch cranks eat up a ton of duration) he has currently a high 11 sec combo.
[Re: OA5599]
#994158
05/18/11 07:44 PM
05/18/11 07:44 PM
B3422W5
Portage,michigan
Just to add a little more info... Heads flow right at 300 CFM. 2.08 valves as well...
Question...
Those heads are without a doubt good heads.
As you spent the money for them, are you planning at some point to use the potential they have, because the rest of your combo is more suited to just using cleaned up Eddies. Not picking on you( not trying to anyway ) but you have more " head" than what the rest of your combination/intentions is going to use.
[Re: OA5599]
#994161
05/21/11 03:11 PM
05/21/11 03:11 PM
Posts: 2,128 sweden
sshemi
sweden
so how did it run? Id bet at 11.8 because of the fact that it is a street car. What works on the roads dont work at the track. Aldough 550 hp should get it ti go high 10s. Tell us please.
[Re: sshemi]
#994162
05/21/11 04:44 PM
05/21/11 04:44 PM
Posts: 7,506 Az
Crizila
Az
I heard it went 11.65 and change. Guess I win Pay dis window.
Fastest 300
