Small oil pan leak #994116
05/17/11 10:56 AM
05/17/11 10:56 AM
DES MOINES IOWA
P
PARTSMAN440 Offline OP
P
DES MOINES IOWA
I have a small oil leak on the bottom of my pan. Is there any fix other than dropping the pan. Maybe JB weld or silicone. It in the center on the bottom of the pan. Help.
Re: Small oil pan leak [Re: PARTSMAN440] #994117
05/17/11 11:01 AM
05/17/11 11:01 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Weld it... I did that on my Jeep... drain the oil
clean the out side and weld it
Re: Small oil pan leak [Re: MR_P_BODY] #994118
05/17/11 11:18 AM
05/17/11 11:18 AM
tboomer Online work
tboomer  Online Work
Tim...You should have had Jimmy take care of that when it was up in the air...How do you like your new chassis set up?? Got any pics??
Re: Small oil pan leak [Re: tboomer] #994119
05/17/11 11:23 AM
05/17/11 11:23 AM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
I had a pin-hole in my 62 pan some years back. Drained the oil.... hit it with a proPAIN torch with some acid solder ...NO problemO.
Re: Small oil pan leak [Re: tboomer] #994120
05/17/11 11:36 AM
05/17/11 11:36 AM
DES MOINES IOWA
P
P
DES MOINES IOWA
I didnt known I had a leak till I got home last night and looked uner the car. Had about a 5 inch puddle under the pan.
I posted yesterday about the new ladderbars. Great job done by Jim and the crew. Jim took some pics and said he would postthem
Re: Small oil pan leak [Re: PARTSMAN440] #994121
05/17/11 11:42 AM
05/17/11 11:42 AM
tboomer Online work
tboomer  Online Work
OK....I missed that post...Jimmy and the boys do a great job!! Can't wait to see pics...
Re: Small oil pan leak [Re: PARTSMAN440] #994122
05/17/11 12:43 PM
05/17/11 12:43 PM
Florida-West Coast
Thor500 Offline
Thor500  Offline
Florida-West Coast
When mine leaked, I drained it welded it then siliconed it.
Re: Small oil pan leak [Re: PARTSMAN440] #994123
05/17/11 08:57 PM
05/17/11 08:57 PM
do you know Murphy, he hates Mopar drag racers Take it off and fix it right
