Re: Bring your Alternator Pictures! [Re: scratchnfotraction] #993215
05/25/11 05:35 PM
05/25/11 05:35 PM
scratchnfotraction Offline
BB and SB do not mix and are different mounting brackets
Re: Bring your Alternator Pictures! [Re: pinkduster] #993216
05/25/11 05:37 PM
05/25/11 05:37 PM
Near Reading PA USA
pinkduster Offline
pinkduster  Offline
Near Reading PA USA
Sorry about that big picture, but that really shows how it should be.
I agree with scratchin... You can't mix and match AC and non AC parts. I had major issues like that years ago with one of my 71 Dusters that had an aftermarket AC setup on it at one time. Finally, I just went to a junkyard and got all non AC brackets and pullies.
Re: Bring your Alternator Pictures! [Re: hooziewhatsit] #993217
05/25/11 06:58 PM
05/25/11 06:58 PM
Just so it's clear, I made a picture
Move the bracket to the front, and line up the holes as colored:
this bracket wont flip around and bolt up,it has 4 holes,the alt pivot hole is offset from the 2 holes that are right together,the 4th hole is for the a/c comp bolt
Re: Bring your Alternator Pictures! [Re: scratchnfotraction] #993218
05/25/11 07:07 PM
05/25/11 07:07 PM
hooziewhatsit Online content
hooziewhatsit  Online Content
D'oh Thanks for the additional clarification
Re: Bring your Alternator Pictures! [Re: geol] #993219
05/25/11 07:23 PM
05/25/11 07:23 PM
old picture of 69 340
FYI,this is a early style non a/c alt bracket and pulley set up that has 3 bolts in the early cast iron pumps
the later non a/c alt bracket only have 2 bolts on the later style alum pumps
this means you need the early bracket with early pullys
and later alt brackets with later pullys
cant mix these setups either,IIRC
not sure how much the brackets changed when they changed to a sanden a/c comp..it has same alt pivot with bolt and nut,2 bolts to head and moved hole for comp making for 2 diff style brackets going by yr
hoozie..it would be correct if it was the 3 hole non a/c bracket,you are thinking correct on the bolting up part
Re: Bring your Alternator Pictures! [Re: scratchnfotraction] #993220
05/26/11 08:12 AM
05/26/11 08:12 AM
Rhode Island
Caparco Offline OP
Caparco  Offline OP
Rhode Island
So i can't use the lower A/C Y shaped lower bracket with the Non-A/C 3 hole triangle top bracket? and at the end of the long bolt on the top, does it go all the way through and then into the head.. that big pic is nice but it doesn't show.
Im so confused and its a big mess now of mis-matched parts, I have 2 pullies on my alternator but only use 1 since my A/C was ripped out
thanks for the color diagram, but i already tried to flip it, like you showed and it didn't line up at all, and to add the big pic there shows 3 holes on the right of the triangle bracket, I only have 2 in my water pump
~ 72 Dodge Challenger ~
~ 97 Dodge Neon ~
~ 97 Dodge Ram ~
Re: Bring your Alternator Pictures! [Re: Caparco] #993221
05/26/11 09:37 AM
05/26/11 09:37 AM
ok,yes you may use the lower Y slide bracket with the non a/c alt 3 hole bracket it would share the same lower side bolt on the water pump
on non a/c alt bracket the pivot bolt goes into the hole in the head,bracket for front of alt on pivot bolt with spaces in place,2 long side wp bolts holding bracket
now the alt is hung..
swing arm goes on lowr side wp bolt to swing up to alt bolt
the bracket you need goes across the bolts on the top of wp
this is a/c brackets,the alt pivot bolt does not goe in the head but into the offset hole of bracket with pivot bolt and nut...like you have now
all you need is a a/c comp front bracket to support the front of the alt and push it back in line
you have a belt straight to the crank bypassing the a/c comp now
it may need to be a little longer when you get the front bracket
dont look at the BB pic posted and when looking at the SB pics they have non a/c brackets and pullys so you cant get that with what you have on there now
you could take some flat bar and drill holes in each end then support the front of alt from a water pump bolt,line it up with the belt off and get it supported first then install a correct length belt
if you look at the sb with a/c,you see the 2 belts over the top of the a/c comp going to the alt,you need that front bracket on the a/c comp
then run the belts down to the crank like you have it now
clean up the web/rib on the wp neck and you will get both belts like the a/c used on the alt
if you want a true later style non a/c set up you need a non a/c 1 groove wp pully and a 2 groove crank pully for ps
they have a single groove crank pully for non a/c manual steer also when your looking so remeber 2 groove for ps
also looking at the sb pics some of the non a/c brackets have 3 bolts in the wp and the alt pivot bolt into the head...those are for an early style cast iorn wp.. may or may not work on alum wp
but the exploded pic of the brackets are what you want with 2 correct pullys to match for non a/c and ps
now you fused?
Re: Bring your Alternator Pictures! [Re: scratchnfotraction] #993222
05/26/11 09:42 AM
05/26/11 09:42 AM
look at the pic of the 73 cuda
you want that front bracket holding the a/c comp
see how it goes behind the a/c pully and over to the alt pivot bolt
thats what you need and your done
just the wp mod to run the 2 short belts just like you have on there with the 1 belt
Re: Bring your Alternator Pictures! [Re: pinkduster] #993223
05/26/11 10:23 AM
05/26/11 10:23 AM
Carson City, NV
babarracuda Offline
babarracuda  Offline
Carson City, NV
On the engine stand
Re: Bring your Alternator Pictures! [Re: babarracuda] #993224
05/26/11 11:51 AM
05/26/11 11:51 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Out of all the eng pics I have taken this is the best showing at least a little of the alt mounting. Ron
Re: Bring your Alternator Pictures! [Re: babarracuda] #993225
05/26/11 02:58 PM
05/26/11 02:58 PM
Washington
19cuda73 Offline
19cuda73  Offline
Washington
Heres a shot of a 73 cuda 340 no AC car alternator shot.
1966 Charger 383 4 speed (Black with Red interior)
1973 Cuda 340 4 speed (Lemontwist)
1972 Corvette
Re: Bring your Alternator Pictures! [Re: 19cuda73] #993226
05/26/11 03:55 PM
05/26/11 03:55 PM
but he has the a/c brackets and pulleys and is bypassing the a/c comp doing it the shadetree way on the cheap.
going by his pic posted anyways,he is just missing the front a/c bracket to hold the alt.
he will need the 2 non a/c pulleys and alt bracket to chang over to non a/c and LOOK correct.
Re: Bring your Alternator Pictures! [Re: 19cuda73] #993227
05/26/11 07:15 PM
05/26/11 07:15 PM
Rhode Island
Caparco Offline OP
Caparco  Offline OP
Rhode Island
wow thats a nice pic! ty!.. and yes I am using a/c mounts and have to get the triangle non-A/c one.. I hope the bottom Y adjuster bracket will work with it still.
My Question is that top bolt.. that gets the small spacer and then gets bolted into the head??, can't tell from pic, or is there a bolt at end of it?
There is a hole near that on head.. you can see from my pic its where i had it bolted to
~ 97 Dodge Neon ~
~ 97 Dodge Ram ~
Re: Bring your Alternator Pictures! [Re: Caparco] #993228
05/27/11 03:59 PM
05/27/11 03:59 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
'88 Gran Fury cop car
Facts are stubborn things.
