My car was set up as 16V when built and all of that stuff has the step down relays, but I would call the manufacturers and ask. From what alot of people say, you probably don't need them, but if you have the electric solinoid on an accusump, I know that needs it. Then again, after our conversation earlier you said you had a dry sump set up, so just check with the manufacturers to be sure. You'll like it though. Like folks said, when the voltage gets below 16V, school's out, so a voltage gauge and alternator are a good idea.
