Re: FInding IC on a 4 link
[Re: WILD BILL]
#992722
05/15/11 12:37 PM
05/15/11 12:37 PM
Posts: 16,941 NC
440Jim
NC
I have a MicroSoft Excel file that does 4-link instant center calcs. But the board doesn't allow attaching. Quote:
The files you may upload must have the following extension: .gif,.jpg,.txt,.zip,.png,.pdf,.jpeg,.JPG,.GIF
If you would like it, email me. Here is a picture of it. You need to put actual hole location measurements into it to match your car. Then you can change holes to see where the IC goes to.
[Re: 440Jim]
#992723
05/15/11 12:49 PM
05/15/11 12:49 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
[Re: 440Jim]
#992726
05/15/11 02:30 PM
05/15/11 02:30 PM
Posts: 4,821 Moved to N.E. Tennessee
GomangoCuda
The files you may upload must have the following extension: .gif,.jpg,.txt, .zip ,.png,.pdf,.jpeg,.JPG,.GIF
Jim, can you Zip the Excel file and attach that?
[Re: springers340dart]
#992727
05/15/11 02:31 PM
05/15/11 02:31 PM
WILD BILL
BROOK PARK, OH
OK, here's the locations of the bolts (center) of each bar location.
They are the same left or right.
Upper front; 16" Upper rear; 19 1/2" Lower front; 8 3/4" Lower rear; 8 1/2 "
I'll have to try and draw a pic on the computer to show what my hole loactions do as they are curved and not in a straight line.
However, the front upper holes are 3/4' on center. The front bottom areand both upper and lower rear hole are 1 " on center.
I think my heads gonna explode now
[Re: WILD BILL]
#992728
05/15/11 02:36 PM
05/15/11 02:36 PM
GomangoCuda
Just get a piece of chalk and draw it on your garage floor or use thumbtacks and string on your wall.
[Re: WILD BILL]
#992729
05/15/11 02:40 PM
05/15/11 02:40 PM
Posts: 1,752 detroit area
moderncylinder
detroit area
so you are saying that your passenger bar is 1/4" longer than the drivers side? so you have "reverse" preload? to preload the bar you would shorten it on the passenger side as compared to the drivers side in,, and 1/4" would be alot,, maybe thats your problem
i wouldnt change the 4 link positions, it looks like the car left ok and the tire looks ok,,, adjust your preload
scale the car with you in it ready to race first,, or after you just change the length of the top passenger bar
[Re: GomangoCuda]
#992730
05/15/11 02:41 PM
05/15/11 02:41 PM
WILD BILL
BROOK PARK, OH
I got it all on paper but would need to do it in PAINT or something like that for you guys to be able to see it.
My drawing ability is worse than my reaction times
[Re: Dragula]
#992733
05/15/11 03:14 PM
05/15/11 03:14 PM
WILD BILL
BROOK PARK, OH
I don't have acsess to scales
I'll try the sliding bolt method but my bars don't have any flats so I'll just have to try and eye ball a 1/2 turn.
[Re: WILD BILL]
#992734
05/15/11 03:22 PM
05/15/11 03:22 PM
WILD BILL
BROOK PARK, OH
My mistake.
I just went to adjust the bars and remeasured to verify my starting point and I WAS WRONG.
BOTH upper bars are 19" long.
I'll go back up and edit the above post.
Then double check all the rest of my measurements
[Re: GomangoCuda]
#992736
05/15/11 03:38 PM
05/15/11 03:38 PM
WILD BILL
BROOK PARK, OH
To set preload I would take the right front upper bolt out and adjust the bar so that the bolt just slides in. Then shorten that rod say three flats to preload the right side a little and try it out.
OK, I did that and quit frankly I think it's right back where it was to begin with but at least know we know what the sarting point is.
Bout a half turn of preload.
