Re: Budget 440
[Re: ralphie361]
#991138
05/13/11 01:49 PM
05/13/11 01:49 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
I have an old 484 purple shaft or a new comp xe 274 that I could use. Wouldnt be against getting something else. Also have a performer manifold, will run headers, not sure on carb. Car is an automatic with a 2600 stall and 323 gear, but have 391s in the garage if needed/wanted. Thanks!
no way i'd even think about the 484. The Xe would probably like more gear but between the 2 I'd go w/ it
Re: Budget 440
[Re: ralphie361]
#991142
05/13/11 10:43 PM
05/13/11 10:43 PM
Posts: 30,488 Florida STAYcation
dOc …
The village idiot's idiot
Florida STAYcation
Do you guys think I am getting a whole lot more compression with this head swap, or not enough to worry about? I heard somewhere that an old racer trick was to put 915s on a hp440 and you get about 13 to 1 comp., different starting comp ratio I know, but definately not what I want! I am not really an engine builder, I usually just freshen what is there and go with it. Thanks!
The 915's are a good choice .. but no where near not-even-close to 13 to 1 .... probably something like the 6 Pack ... an honest 10.2 to 10.5.
Re: Budget 440
[Re: dodgefarmer]
#991145
05/14/11 02:26 AM
05/14/11 02:26 AM
Posts: 5,221 Branson, Mo.
joedust451
super gas
super gas
Branson, Mo.
The 440 6 pack had a "true" compression of right around 9.7.1 & thats with open chambered heads that came on it, The 71 440 "might" i say might but you should measure have the pistons down around .080"-.090" in the whole, if so, with an open chamber the compressions around 8.6.1, You should be able to run the 915s & be fine on pump 93, the compression will most likely be around 9.2-9.3 with a steel shim gasket, You can't really say it'll have better/good quench, but it should have a better burn do to less chamber volume in the head, an old trick is grind off any casting flash & smoothin out the chambers, this will prevent any "hot spots" that can cause detination, run a plug 1 step colder then stock, like a J11Y, The XE274 would be my pick, plenty of torque & good power & vacuum, It will still be a strong runner with 3.23s, will kick ass with a set of 3.91s. Drop a 750dp & an RPM.
