67 383 cly head bolt sealant and lube
#990879
05/12/11 09:57 AM
05/12/11 09:57 AM
Posts: 342 dracut mass usa
sparcy
dracut mass usa
swaping a set of rebuilt heads onto my 67 383 schould I put thread sealant on bolts around water jacket bolts ? I have arp sealant and arp lube . I heard not to run a tap down the bolt holes takes off to much metal ? going to reuse factory bolts just a stock rebuild . I got felpro gaskets 8519 pt-1. any thoughts ? thankyou
IF YOU ARE NOT WRECKING STUFF YOU ARE NOT LEARNING !
Re: 67 383 cly head bolt sealant and lube
[Re: sparcy]
#990880
05/12/11 10:02 AM
05/12/11 10:02 AM
Posts: 21,070 Niles , Ohio
therocks
Niles , Ohio
My machinist uses a self bottoming thread chaser not a tap.A regular tap wont bottom in the block.Make sure the thread hole is clean.I spray brake clean and use compressed air to blow the hole out.No sealer needed just lube.Use ARP spec to torque with lube.Rocky
Chrysler Firepower
[Re: JohnRR]
#990882
05/12/11 10:55 AM
05/12/11 10:55 AM
therocks
Niles , Ohio
John without knowing comp etc or what he wants from the motor they will work.For just a cruiser he shouldnt have any problems.Myself Id use 1009s unless he wants to up the compression.Rocky
Chrysler Firepower
[Re: therocks]
#990883
05/12/11 11:37 AM
05/12/11 11:37 AM
Posts: 75,004 U.S.S.A.
JohnRR
U.S.S.A.
He sent me a PM , switching from closed chamber heads to open chamber, he's going to need all the help he can get if it has stockish flatops.
[Re: JohnRR]
#990884
05/12/11 12:04 PM
05/12/11 12:04 PM
therocks
Niles , Ohio
I agree thats about a point drop.But if its just a cruiser it should still be ok.They were rated at what about 10 to 1.Rocky
Chrysler Firepower
[Re: therocks]
#990887
05/12/11 02:23 PM
05/12/11 02:23 PM
JohnRR
U.S.S.A.
The 4bbl is rated at 10.0 butit'se more like 9.2 at best, so depends on what engine he is starting with .
