Re: Orange Peel.
[Re: racerx]
#990531
05/11/11 08:06 PM
05/11/11 08:06 PM
Posts: 21,833 Kirkland, Washington
Pacnorthcuda
Man I hope the above poster wasn't serious! Orange peel is inadequate flow-out of wet paint. the faint failed to flow into an even film. Causes, potential causes are many, including, but not limited to: Inadequate film build To high temperature To little reducer to low spray pressure poorly adjusted gun (poor atomization) poor quality paint to long of flash time between coats to fast of reducer and other reasons
Re: Orange Peel.
[Re: Boise Chall]
#990533
05/11/11 08:54 PM
05/11/11 08:54 PM
Pacnorthcuda
Pacnorth you might want to call your PPG or paint rep before you question my reply. You might learn something.
REALLY? You're saying they sell an additive for people who WANT orange peel? Or could the additive be for 'eliminating' orange peel?
Do you think the original poster is asking for something he can put in the paint to cause it?
REALLY?
Re: Orange Peel.
[Re: Pacnorthcuda]
#990535
05/11/11 09:41 PM
05/11/11 09:41 PM
Posts: 587 IL . usa
cjs69mope
IL . usa
it amazes me when you ask paint questions how many different opinions you get are they right are they wrong ? nobody knows as far as the two above answers you guys are both right . It all depends on the conditions and the painter what works for some in for example in Canada may not work in Florida . from garage to paint booth in the same climate is apples to oranges i paint in the garage and i guarantee my work is better then some of the expensive body shops around here . i think it all is trial and error and learning what works for your situation and you.
1969 Dodge Charger
1969 Dodge Superbee
Re: Orange Peel.
[Re: hotairballoonpilot]
#990540
05/12/11 11:00 AM
05/12/11 11:00 AM
Posts: 659 Boise Idaho
Boise Chall
Boise Idaho
It's not a product you can buy !!! The P-A-I-N-T M-A-N-U-F-A-C-T-U-R-E-R puts it in the P-A-I-N-T when the paint is made. Factory vehicle paint has orange peel in it because the vehicle manufacturer either dips the car body in paint or sprays it quickly then forces it to dry fast by baking it. Either way the paint doesn't have time to flow out or lay flat so it has orange peel. You can make orange peel less noticeable by putting more material on with each coat, over reducing, using slower hardener for the temp that your spraying in, slamming the paint droplets onto the surface by using more air pressure when spraying, but the only way to get completely rid of it is to wet sand it flat and polish it. Wet sanding is the final process of any quality or showcar paint job like ones found on a Bently, Ferrari, Jaguar, Foose, Codington etc. Call your paint rep or go take classes on how to paint they teach you things like this. Or take some of the advice here and hang voodoo dolls in your paint booth or use a garden hose to spray it on or turn 3 times to the left the twice to the right then jump up and down 4 times before each coat It looks like we did a fine job of chasing the OP away and probably left him more confused than when he asked the simple question.. WOOHOO strike one up for the MIDOL militia. and by the way I might have a little experience painting cars http://www.moparmax.com/features/featurecar/v_5-resurrection-1.html
Re: Orange Peel.
[Re: RemCharger]
#990546
05/12/11 01:46 PM
05/12/11 01:46 PM
Posts: 5,668 South Dakota
hotairballoonpilot
South Dakota
wow what can I say. I think I will just sit back and watch you make pretty interesting claims and bash people. Please do show us your "projects"
Contact Me about AMD Prices
Re: Orange Peel.
[Re: AdamR]
#990548
05/12/11 03:12 PM
05/12/11 03:12 PM
Posts: 144 Blair, NE
cudacam
Blair, NE
Wow! That color looks good on a Cuda. What is it? nice job.
