Page 4 of 5 1 2 3 4 5
Re: small block spead port head [Re: tubtar] #989534
05/13/11 05:17 PM
05/13/11 05:17 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
I forgot to mention Commando.
Don't even get me started on Commando's.
I leave out Magnums intentionally.
Re: small block spead port head [Re: tubtar] #989535
05/13/11 06:29 PM
05/13/11 06:29 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Well, I have a feeling this will go the way of the Ritter blocks, alot of asking when are they coming out, and to show up on stage in front of a broke audience.
Re: small block spead port head [Re: Hot 340] #989536
05/14/11 09:50 PM
05/14/11 09:50 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Could we get a definition of the different terms being thrown around? Whats the diff between spread port and splayed port? Is a splayed port like the SB2 Chevy heads? Didn't they call those mirror ports?
Re: small block spead port head [Re: S/ST 3040] #989537
05/15/11 10:11 AM
05/15/11 10:11 AM
IL
knyech1 Offline
knyech1  Offline
IL
I need to keep track of this, in case some pictures show up.
Me too
knyech1- '71 Sassy Grass Demon 340/904. Pump gas, 1.61 60ft, 7.439 1/8 @ 95mph, 11.824 1/4 @ 111mph "Not too bad for a pump gas 340, full of used parts and hillbilly ported stock heads." - V.B. '03 2500 5.9L HO 6-spd on 35's. 395hp/755ft-lb at tires.
Re: small block spead port head [Re: Hot 340] #989538
05/15/11 10:57 AM
05/15/11 10:57 AM
Niles, Michigan
Hitman340 Offline
Hitman340  Offline
Niles, Michigan
In most cases.
Re: small block spead port head [Re: Hitman340] #989539
05/15/11 11:29 AM
05/15/11 11:29 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Nice block hitman!
Our best set of iron heads on our poor boy 360 has small stem chevy valves in them Kasey. Just a bunch of "little things" that added up to a cheap 10.9 combo in our Duster.
Looking forward to seeing if this head comes about, but then again, I'm more of a looker. Our W5's have more than met our needs.
Re: small block spead port head [Re: Hitman340] #989540
05/15/11 11:50 AM
05/15/11 11:50 AM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
In most cases.
That looks beefy as he11!
i knever managed to find any online prices on those:/
Re: small block spead port head [Re: Moparnut426] #989541
05/15/11 01:30 PM
05/15/11 01:30 PM
NC
SLOW67 Offline
SLOW67  Offline
NC
I just see expensive parts.
I hope not, and its great theres companies out there doing mopars favores and such. and you are correct the polly had canted heads.
I just know Ill never be able to afford them.
like I said I just like the good ol wedge design witch works.
Kasey
Can't help but agree with you on that. Yes it is exciting to see a new part come our way, but when the cost is so high they are just going to be another piece for the high end guys. And no I'm not hating on the high end people either but It would just be nice to see something new be alittle less exoitc and more geared towards the grassroots racer
Re: small block spead port head [Re: SLOW67] #989542
05/15/11 01:47 PM
05/15/11 01:47 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
Kasey
i dont know about that, there is Edelbrock and RHS out there,another step up from that is basicly indy and W-series stuff and thats where people start complaining about cost for some reason,what market is there realy to fill?
Re: small block spead port head [Re: 1Fast340] #989543
05/16/11 12:46 PM
05/16/11 12:46 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Honestly I didn't say anything about the cost. I just pointed out that from the information posted thus far, they aren't any better then what's availible.
Re: small block spead port head [Re: dizuster] #989544
05/16/11 07:39 PM
05/16/11 07:39 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Well I for one can't wait to see what you come up with
WIZE
In Car:
Re: small block spead port head [Re: Streetwize] #989545
05/16/11 07:46 PM
05/16/11 07:46 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
I'll second that!
Alan Jones
Re: small block spead port head [Re: LA360] #989546
05/16/11 08:21 PM
05/16/11 08:21 PM
Q
Quicktree Offline
Quicktree  Offline
Q
where did he go
Re: small block spead port head [Re: Streetwize] #989547
05/16/11 09:01 PM
05/16/11 09:01 PM
Texas, USA
ChrgrCuda Offline
ChrgrCuda  Offline
Texas, USA
68 Cuda Notchback [Email]10.86@120[/Email] 69 Charger R/T 440/505 2009 Challenger SRT8
Re: small block spead port head [Re: ChrgrCuda] #989548
05/16/11 11:47 PM
05/16/11 11:47 PM
IN
Irun5snd8th Offline
Irun5snd8th  Offline
IN
How much one of those Ritter blocks cost?
AFCO, Rons Fuel Injection sponsored Dodge Challenger Mention Street Lethal Motorsports
Re: small block spead port head [Re: johnl1961] #989549
05/17/11 12:00 AM
05/17/11 12:00 AM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
We are trying to use a stock rocker!
Whoa whoa whoa!!! Stock rockers on a small block mopar use a shaft design. A single shaft design. If I'm going to run a canted valve, spread port head, I sure as he!! won't be using stock rockers. For two reasons: One, stock rockers suck. Two, it's impossible to use a single shaft rocker setup on a canted valve engine. It seems you're throwing out a lot of hype without any real details.
I hope you'll forgive my skepticism, but I'm smelling something here and it ain't roses. I will happily eat my words later if this comes to fruition, but at least be honest. This will require a different intake manifold, different headers (which I know you already said), different rocker arms and different pistons. This will not be "cheap". It may be a relatively "cheap" way of making power, but I would rather it be labeled an alternative way of making power.
Ok, stepping off the soap box.
Re: small block spead port head [Re: dodgeboy11] #989550
05/17/11 12:11 AM
05/17/11 12:11 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Mabey it will use stock magnum rockers or poly rockers. Mabey the valves will end up nearly straight up and down so they don't come close enough to flat top piston to need valve releifs. I am sure it will be expensive, no way around it when you can not use an existing cam, intake or headers. Mabey they can use a few stock items but a lot will need to be changed and the cost will add up. Probably end up being cheaper to just build an CNC ported eagle headed 400 inch new hemi.
Re: small block spead port head [Re: dodgeboy11] #989551
05/17/11 12:02 PM
05/17/11 12:02 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
never said it was a stock MOPAR rocker...my guess would be they're using chev geometry shaft mount rockers....
2017 Grand Cherokee Overland
Re: small block spead port head [Re: patrick] #989552
05/17/11 01:37 PM
05/17/11 01:37 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
i would also gues on somekind of chevy or ford rocker, probably wouldnt be impossible that ford pistons could be an alternative also with a bit of luck
Re: small block spead port head [Re: Quicktree] #989553
05/17/11 01:57 PM
05/17/11 01:57 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
where did he go
I was wondering the same thing.
