Roller bearing vs std bearing cam RB/hemi?
#987381
05/06/11 10:31 PM
05/06/11 10:31 PM
Posts: 1,212 QLD Australia
Keith Black®
QLD Australia
Looking to understand the benefits of a roller-bearing large journal cam over std journal bearing-type cam when the specs would otherwise be identical. Assume in this instance a solid roller cam circa .700 lift @ the valve. Durability? Performance improvements? I understand you would use larger journal cam where the lift/base-cricle combo is large enough that you otherwise wouldn't get the cam into the block.. but what other benefits have you had? I can order my new KB block this way. durability important. Does it effect valve train oiling?
-------------------------------- Darren Beale Keith Black Racing Engines®
Re: Roller bearing vs std bearing cam RB/hemi?
[Re: Keith Black®]
#987384
05/06/11 10:52 PM
05/06/11 10:52 PM
Posts: 52,972 Romeo MI
MR_P_BODY
With a roller bearing set up you will have a much larger cam all the way through... big means strong so you have less flex specially with big roller springs
[Re: Diablo]
#987386
05/07/11 12:12 AM
05/07/11 12:12 AM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
On some engines I build I use big cores but still use regular bearings. Roller bearings do some strange things. .700 lift? Thats mild, my wedge has .850 at the valve with 1.7 rockers and billet steel round lobe regular size core, i take it to 8200. The ford size is a good step up and still reasonable to get a cam ground. Jesel makes 60mm regular coated bearings if you feel the need to go that big. i just happen to have a pic of a set with the part number: Gear drive and roller bearings? I would pass on that combo. If you never built a roller bearing engine make sure you have help from someone that does because you have to tailor your oiling around it. If you do decide to use a big core make sure you get it rifle drilled cause its Heavy!!!!
BB, TT5,Procharged 3300lb Street Car 4.79/154
[Re: bigtimeauto]
#987388
05/07/11 12:39 AM
05/07/11 12:39 AM
MR_P_BODY
Wow.... I run a 50 MM cam at .700+ lift with a gear drive on my SB
[Re: Keith Black®]
#987390
05/07/11 12:59 AM
05/07/11 12:59 AM
bigtimeauto
Trophy Winner
Trophy Winner
I don't think longevity is going to come from roller cam bearings. You get more harmonics and more pieces to fail inside your engine.
Another thing i forgot. If you go with a bigger core and use pushrod oiling MAKE sure you check where your lifter band hole is in relation to your lifter oil galley!!!
[Re: Keith Black®]
#987393
05/07/11 02:52 AM
05/07/11 02:52 AM
Posts: 903 Saskatchewan, Canada
cudabin
On my new KB bock I went for the 54mm cam core using std bearings which is a no charge up grade. I am confident it will work fine... The bigger cam core is stronger for less deflection! Roller bearings have their place, but it is not really a reliability thing, it is more to withstand severe loading from big cams and huge spring pressure IMO... Good luck with the build. Arnie
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...)
70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
[Re: tubtar]
#987395
05/07/11 04:04 PM
05/07/11 04:04 PM
bigtimeauto
Trophy Winner
Trophy Winner
correct on the oiling. There is no hole in the bearing so they get all of there oil from splash. Not a great idea for longevity especially at low rpm.
