Re: indy heads one darker in color than the other??? [Re: DemonDust] #986980
05/06/11 09:22 PM
05/06/11 09:22 PM
Wis.
rlm2268 Offline OP
rlm2268  Offline OP
Wis.
I acually bought them a while back from a moparts member on here, he said he got them directly from indy. I didnt try any aluminum cleaners yet. I'm guessing it might have to be a acid type alum. cleaner to do anything. I'll figure something out.
I didn't get in touch with gritzmacher yet about doing a valve job, just deciding on what valves to order and cutting the heads for spring cups.
Re: indy heads one darker in color than the other??? [Re: rlm2268] #986981
05/07/11 07:42 AM
05/07/11 07:42 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
If you bought them other than direct from Indy,someone may have beadblasted one head.When we clean and redo old heads(beadblast) they come out with a dull finish.
Re: indy heads one darker in color than the other??? [Re: rlm2268] #986982
05/07/11 09:12 AM
05/07/11 09:12 AM
NC
440Jim Offline
440Jim  Offline
NC
Well, I hope it is not a functional issue (casting problem). I wouldn't expect any head company to do anything about color appearnce... If you had bought them recently from a registered dealer, they might go above and beyond if it was possible. And since they are technically used heads now (changed owners), I don't expect anyone to do anything.
Check them out carefully, and just do whatever appearance/cosmetic finish you want. Just a reality check, sorry.
Re: indy heads one darker in color than the other??? [Re: rlm2268] #986983
05/07/11 09:17 AM
05/07/11 09:17 AM
NC
440Jim Offline
440Jim  Offline
NC
... just deciding on what valves to order and cutting the heads for spring cups.
From all the posts about rocker clearance, be sure and get valves long enough to not need +0.050" retainers, or lash caps. If they are a touch long, you can put -0.050" retainers on and that should give even more retainer to rocker clearance.
But if you are going with 1.5" dia springs and a low installed height (1.90"), then it shouldn't be an issue. If you want 1.95-2.00" and/or 1.625" springs, give this attention when buying valves.
This is when a race head shop is worth the money to get it right the first time instead of band-aiding the the issue.
Re: indy heads one darker in color than the other??? [Re: 440Jim] #986984
05/07/11 09:18 AM
05/07/11 09:18 AM
Q
Quicktree Offline
Quicktree  Offline
Q
second hand changes the whole ball game. no telling whats been done to them.
Re: indy heads one darker in color than the other??? [Re: Quicktree] #986985
05/07/11 12:22 PM
05/07/11 12:22 PM
Wis.
rlm2268 Offline OP
rlm2268  Offline OP
Wis.
The heads for sure have not been used and not blasted. One thing is the cnc porting looks nice and they are the cnc castings.
I'm thinking maybe ferrea 6000 series valves and isky 8005a springs for a solid flat tappet cam.
