Re: Grudge race advice
[Re: pinkduster]
#986882
05/07/11 06:37 PM
05/07/11 06:37 PM
Posts: 1,212 Canton, Ohio
Crazy68Dart
Canton, Ohio
I think you are in trouble, to be honest. Those are the 5.4 with the supercharger, correct? If it is the same setup as I am thinking, only a few little mods get a lot of power out of those things. FWIW, the new 5.0s are making 400+ hp from the factory, idle like a pooch and get 25+ MPG on the highway. I say Ford is doing something right. Fine with me, American all the way! ![](/ubbthreads/images/graemlins/thumbs.gif)
383, Hemi 4-Speed, AlterKtion, D60
[Re: pinkduster]
#986884
05/07/11 09:23 PM
05/07/11 09:23 PM
Just go hammer him. I bet it won't be as difficult as some assume. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: quick77rt ]
#986886
05/08/11 10:23 AM
05/08/11 10:23 AM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
Is this still Moparts the Best Mopar Site on the internet????? I am use to hearing this kind of talk at the track before they see my Mopar run,but to hear it on a Mopar site. ![](/ubbthreads/images/graemlins/tsk.gif) WAKE UP PEOPLE ![](/ubbthreads/images/graemlins/biggrin.gif) Quit bad mouthing all that Indy stuff(you can buy it from dealers on here not Indy)and start buying it and put it on your cars. :cool Its time you all stop ![](/ubbthreads/images/graemlins/bow.gif) down to them x-brand cars. ![](/ubbthreads/images/graemlins/devil.gif) Its true I may spend a lot of Hard earned $$$$ on my Mopar but them x-brand people have to ![](/ubbthreads/images/graemlins/bow.gif) down to me,not the other way around. ![](/ubbthreads/images/graemlins/devil.gif) Stand up for your fellow MOPAR Racers,never ![](/ubbthreads/images/graemlins/bow.gif) to them furds & chebbies AGAIN!!!! ![](/ubbthreads/images/graemlins/beer.gif)
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
[Re: Silverbullet2]
#986888
05/08/11 07:45 PM
05/08/11 07:45 PM
Posts: 1,141 Phoenix,Az.
hemicop
Phoenix,Az.
A former co-worker has an 09 Shelby GT500 and has talked some smack all along. I'd really enjoy showing him the backside of the X. I really think deep 11s are possible with this car, maybe better, but I haven't been on a dragstrip in years. I'm no Ronnie Sox or Joel Nystrom, but I truly believe I should be able to cover that Shelby. What do I need to do as far as setting up the car and driving technique to get out front and stay there. THANKS GUYS!
"Cudabin" gave you the best advice regarding your car. I'd probably do all he suggested & perhaps looking at ways of loosening up the front-end a bit. As to the race---downplay you & your car's "skill's", admit nothing & pre-arrange the rules. If you can pull him, do it, but keep just a fender on him all the time until you feel confident & are racing for some big money. Run him heads-up only, despite his possible crying of big motor-vs.- little motor. Don't underestimate his driving--he may be "pear-shaped" but HE isn't running, his car is. 50+ isn't really an oldman for racing, so all that argument is moot. You need to practice ---ALOT! Find someone you respect to follow along, gauge your driving & possibly offer some tips. Remember, your car is not a rev-monster like a smallblock, blown DOHC motor can be, so don't even try. As others have said, I think this is gonna be a driver's race......good luck!
[Re: Silverbullet2]
#986892
05/09/11 02:28 PM
05/09/11 02:28 PM
Posts: 5,160 Texas
dannysbee
Texas
This is how a over 50 guy would do it. Put a shift light in it and once you release the clutch on launch preload the shifter like you are trying to make your shift to second. Don't worry as long as you are on the gas you will not pull it out of gear. When the light flashes tap the clutch, not a full blown to the floor petal mash, but enough to take the load off the drive train which will put you near instantly into second. Repeat for third and fourth keeping the throttle floored this whole process. This along with figuring how many rpm you need on the launch to keep the car from bogging will go along way toward making your GTX perform to its best. Practice, practice, practice and don't be afraid to tear it up, it can be fixed.
Getting old just means you were smarter than some and luckier than others.
[Re: Silverbullet2]
#986893
05/09/11 03:24 PM
05/09/11 03:24 PM
Posts: 11,689 W. Kentucky
justinp61
W. Kentucky
That motor pulls so hard and revs so quickly it's not easy to grab another gear before you're all over the rev limiter.
Are you using a shift light? If not get one, set it 4-500 rpm less than you want to shift, then as you get better set it closer to your shift point.
How much difference (rpm)is there between you're shift point and the limiter? I don't like using a limiter as my shift point.
[Re: 68 HEMI GTS]
#986896
05/09/11 11:02 PM
05/09/11 11:02 PM
Posts: 2,403 WASHINGTON, PA
11secaarcuda
WASHINGTON, PA
That 6000 rpm chip in the MSD needs to go. I would up it to at least 6500.
67 Dart GT 340 4 speed 70 AAR Cuda 408 6 barrel 96 Indy Ram original owner 2011 Hemi Durango
[Re: 11secaarcuda]
#986897
05/09/11 11:10 PM
05/09/11 11:10 PM
11secaarcuda
WASHINGTON, PA
I had a guy like this that ran his mouth all the time about his 04 supercharged Cobra. He had lots of modifications (different pulley on the blower, bigger exhaust, reprogrammed ECM, bigger throttle body, drag radials, etc.) and dyno time on it, and I knew my Cuda was at a power disadvantage. But when the time came, I showed him my taillights big time. He didn't know how to drive the car, and he sold it shortly thereafter. The funny thing is, the shop that did all the work to the car told him that if you can't beat that Cuda, you better sell your car. And he did. LOL. He couldn't even beat a 340 6 barrel Cuda with factory heads, intake, carbs, block, crank...
These new cars just keep getting faster and faster though. Its amazing what you can buy off the dealer lots these days.
[Re: 11secaarcuda]
#986899
05/10/11 08:20 AM
05/10/11 08:20 AM
Posts: 22,873 Chicken coop
dustergirl340
Chicken Little
Chicken Little
Chicken coop
And it's equally amazing how many people can't drive the things. I can't tell you how many races I should have lost but didn't, just because the other driver didn't know what he was doing.
[Re: sasquatch]
#986901
05/10/11 12:56 PM
05/10/11 12:56 PM
Posts: 40 Woodburn,OR
Womanator
Woodburn,OR
I have a couple of fast Mop's A 9 sec and 10 sec Dart. ![](http://i228.photobucket.com/albums/ee81/womanatorjoe/Race%20car/racecar.jpg) ![](http://i228.photobucket.com/albums/ee81/womanatorjoe/Pinks%2009/P7040810.jpg) Now to my 03 Cobra. With just changing to 4.10 gears,Short throw shifter and Superchips program it ran a 12.38 in the 1/4 mile with the traction control on. I've also have seen the Shelby's at the strip struggle with traction and have even helped a couple learn how to drive there cars. All I'm saying is be careful about the race. These cars have the T-56 6 speeds and I never missed a shift in my SRT-10 Pick-up. Good luck.
