where to get? 70 Cuda Ignition switch #986721
05/05/11 06:19 PM
05/05/11 06:19 PM
North Dakota
Azzkikrcuda Offline OP
North Dakota
Need a new ignition switch for my car. I got a wells brand switch PN-ls418, but it doesn't have the same number of wires in the connector. Old switch has 7 wires, new has 6 wires. The wires are also in different slots. Anyone had this problem?
The only Carbs I care about are under the hood!
Re: where to get? 70 Cuda Ignition switch [Re: Azzkikrcuda] #986722
05/05/11 10:28 PM
05/05/11 10:28 PM
What terminal is missing from the wells unit, they're stamped on the back of the black bakelite ie "ign1" "st" ign2" etc. Since your not going original might locate a good used one and it'd b alot of work but worst case you could solder a female connector onto each wire & plug each one in individually depending on which wire/circuit is missing on the Wells but I'm sure you can find a good used one
Re: where to get? 70 Cuda Ignition switch [Re: RapidRobert] #986723
05/06/11 12:20 AM
05/06/11 12:20 AM
IN
ahy Offline
ahy  Offline
IN
I got one for a 70E from Year One a few years ago. Worth checking.
Re: where to get? 70 Cuda Ignition switch [Re: ahy] #986724
05/06/11 12:39 AM
05/06/11 12:39 AM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
According to the 70 manual, there are only 6 wires coming from the ignition switch. The 2 extra 18ga red wires come from the key-in buzzer switch.
Re: where to get? 70 Cuda Ignition switch [Re: RapidRobert] #986725
05/06/11 12:43 AM
05/06/11 12:43 AM
North Dakota
North Dakota
I have not taken the switch out of my car yet to compare them. I had my dad check his Challenger and it has 7 pins also, so I found it odd the new one has six.
Re: where to get? 70 Cuda Ignition switch [Re: Azzkikrcuda] #986726
05/06/11 12:55 AM
05/06/11 12:55 AM
Snoopy Offline
Snoopy  Offline
Key-in buzzer switch.
Re: where to get? 70 Cuda Ignition switch [Re: Snoopy] #986727
05/06/11 01:08 AM
05/06/11 01:08 AM
North Dakota
North Dakota
Thanks for the pic, the indicator lamp location is blank on mine. The key buzzer terminals are blank on the new switch. Looks like the switch should work.
Re: where to get? 70 Cuda Ignition switch [Re: Azzkikrcuda] #986728
05/06/11 01:57 AM
05/06/11 01:57 AM
Snoopy Offline
Snoopy  Offline
Here is an NOS 2947486 Ignition/Starter Switch. It is date coded 323 3, Nov 19, 1973.
It has a black 18ga replacing the original orange 18ga wire.
