where to get? 70 Cuda Ignition switch
#986721
05/05/11 06:19 PM
05/05/11 06:19 PM
Posts: 1,809 North Dakota
Azzkikrcuda
North Dakota
Need a new ignition switch for my car. I got a wells brand switch PN-ls418, but it doesn't have the same number of wires in the connector. Old switch has 7 wires, new has 6 wires. The wires are also in different slots. Anyone had this problem?
The only Carbs I care about are under the hood!
Re: where to get? 70 Cuda Ignition switch
[Re: Azzkikrcuda]
#986722
05/05/11 10:28 PM
05/05/11 10:28 PM
RapidRobert
What terminal is missing from the wells unit, they're stamped on the back of the black bakelite ie "ign1" "st" ign2" etc. Since your not going original might locate a good used one and it'd b alot of work but worst case you could solder a female connector onto each wire & plug each one in individually depending on which wire/circuit is missing on the Wells but I'm sure you can find a good used one
