Where would you put a second temperature sender?
#986151
05/04/11 04:17 PM
05/04/11 04:17 PM
Posts: 289 Toronto, ON
ehbody
Toronto, ON
Where would you put a second temperature sender? Not replacing factory, but additional to say a 2005 Neon 4Cyl.
Shawn
70 AAR
Re: Where would you put a second temperature sender?
[Re: ehbody]
#986153
05/04/11 07:46 PM
05/04/11 07:46 PM
RapidRobert
the easiest place to access the coolant where it is the hottest & if the 2 paired cyls have ex valves next to each other and if you can easily drill/tap the block near the deck at that point that'd b my choice
