What Oil to use in Canada? #986136
05/04/11 04:08 PM
05/04/11 04:08 PM
Toronto, ON
ehbody Offline OP
ehbody  Offline OP
Toronto, ON
I used to use Castrol Syntec, but no longer has the zinc levels. They recommend Edge with syntec, but 5W50, they said this had the zinc content.
They told me must say ok with Vintage on the bottle. BUT not available in Canada. Or is it?
What can I get in Ontario that will keep my engine alive?
Shawn 70 AAR
Re: What Oil to use in Canada? [Re: ehbody] #986137
05/04/11 04:15 PM
05/04/11 04:15 PM
Newfoundland
Crocker Offline
Crocker  Offline
Newfoundland
I use Mobil Delvac 1300 super 15w40 diesel oil with a can of Gm EOS....
Re: What Oil to use in Canada? [Re: Crocker] #986138
05/04/11 05:17 PM
05/04/11 05:17 PM
IN
ahy Offline
ahy  Offline
IN
Rotella T with a can of STP for me. If you want synthetic, the heaviest grade Mobile 1 (15W50?) has high zinc levels.
Re: What Oil to use in Canada? [Re: ahy] #986139
05/04/11 06:24 PM
05/04/11 06:24 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
i use 15w-40 Rotella T with a can of EOS from a GM dealer. If I don't have the EOS on hand I use a can or 2 of the blue STP. The red STP had more zinc but I don't think you can get it anymore.
Re: What Oil to use in Canada? [Re: 440newport] #986140
05/05/11 12:26 AM
05/05/11 12:26 AM
Orleans, Ontario
moparcanuk Offline
moparcanuk  Offline
Orleans, Ontario
Brad Penn. Has the zink required for older motors. Sold only at some Stinson's service stations.
Re: What Oil to use in Canada? [Re: moparcanuk] #986141
05/05/11 09:31 AM
05/05/11 09:31 AM
Eastern Ontario
shaker340 Offline
shaker340  Offline
Eastern Ontario
Whats the reason to use oil with high zinc content for older motors?
I found the answer; http://micapeak.com/info/oiled.html
Nice chart showing what brands have zinc in them.
Mike
2008 Challenger SRT8
1940 Chrysler Royal coupe
Re: What Oil to use in Canada? [Re: shaker340] #986142
05/05/11 10:57 AM
05/05/11 10:57 AM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
just buy good oil and add the additive. lucas , comp and others sell it.
Re: What Oil to use in Canada? [Re: ehbody] #986143
05/05/11 11:09 AM
05/05/11 11:09 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Whatch EOS has been reformulated with no zinc as is mopar crank case conditioner (same product different can) unless you have the old stock from 6 years ago. a friend bought a couple cases before the reformulation.
Brad pen oils semi synthetic or good zinc additive like comp cams and others
http://www.zddplus.com/
http://www.lucasoil.ca/products/product.asp?id=67&cat=HeavyDuty
http://www.summitracing.com/parts/CCA-159/
add one each oil change
Re: What Oil to use in Canada? [Re: Dodgem] #986144
05/05/11 11:13 AM
05/05/11 11:13 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
http://www.bradpennracing.com/testimonials/MikeEtter.aspx
brad penn dealers for us
6. WH Lubricants
185 Frobisher Dr
Waterloo, ON N2V 2E6
Canada
Mr. Richard Habsch
(519) 746-7720
richard@whlubricants.com
Distributor
7. R.P. Oil Ltd.
1111 Burns St E Unit # 3
Whitby , ON L1N 6A6
Canada
Julie Marshall or Steve Shepperdson
(800) 335-6623
steveshepperdson@rpoil.com
Distributor
Re: What Oil to use in Canada? [Re: Dodgem] #986145
05/05/11 11:46 AM
05/05/11 11:46 AM
Toronto, ON
ehbody Offline OP
ehbody  Offline OP
Toronto, ON
Thanks everyone. I think I will use the additive, as I bought the oil last year at a very good price.
But in the future, what about Edge with Syntec?
What about 5W50 for a street driver?
Shawn 70 AAR
Re: What Oil to use in Canada? [Re: ehbody] #986146
05/05/11 01:09 PM
05/05/11 01:09 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I've used Syntec 5 50 for many many years.
Thin cold but retains it's viscosity hot!
in later years just added a zinc additive.
hears another that is good. Break in
http://www.hughesengines.com/Index/products.php?partid=26202
to run in your syntec
http://www.hughesengines.com/Index/produ...mp;partid=23942
Re: What Oil to use in Canada? [Re: Dodgem] #986147
05/05/11 01:11 PM
05/05/11 01:11 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
hughes ontario dealer
ZZ Performance
160 Pony Drive
Unit 8A
Newmarket, ON L3Y7B6
Phone: (905) 895-5831
Email: gord@kpautoelectric.com
Web: http://zzperformance.ca/
Re: What Oil to use in Canada? [Re: shaker340] #986148
05/05/11 01:27 PM
05/05/11 01:27 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
THAT LINK is too old to be useful.
Mike
Re: What Oil to use in Canada? [Re: 05dakota] #986149
05/05/11 01:57 PM
05/05/11 01:57 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
everything has changed and most Shell Rotilla oils have been reformulted for Cat converters too. zinc has been found out to ruin cat converters and as a heavy metal gets in the air. EOS no longer has it but many say go get it it's what i use! It's my fear many use old data when a lot has changed the past 5 years! A LOT!!!
Re: What Oil to use in Canada? [Re: Dodgem] #986150
05/05/11 03:12 PM
05/05/11 03:12 PM
440newport Offline
440newport  Offline
I heard the EOS in the round white bottle is still the old formula, at least in Canada. The one that's shaped like a regular oil bottle is the new stuff.
