MOBIL ONE 0-50 wt #986083
05/04/11 02:43 PM
05/04/11 02:43 PM
SOUTH JERSEY
HEMIFRED Offline OP
HEMIFRED  Offline OP
SOUTH JERSEY
home of the
Sox and Martin Hemi Duster
Re: MOBIL ONE 0-50 wt [Re: HEMIFRED] #986084
05/04/11 02:47 PM
05/04/11 02:47 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
what you really need to know is how well it cleans up off the track and if it's safe on paint, brakes, wheel chrome and tire compounds... right??
Re: MOBIL ONE 0-50 wt [Re: HEMIFRED] #986085
05/04/11 02:51 PM
05/04/11 02:51 PM
Florida STAYcation
dOc ! Online penguin-006
The village idiot's idiot
dOc !  Online Penguin-006
Florida STAYcation
MOBIL makes some big claims about it
JUST LIKE some of those dealers of Amzoil ...
Re: MOBIL ONE 0-50 wt [Re: DJVCuda] #986086
05/04/11 02:59 PM
05/04/11 02:59 PM
SOUTH JERSEY
HEMIFRED Offline OP
HEMIFRED  Offline OP
SOUTH JERSEY
your gonna more mileage from those pics than with the mysterious invisable time slip
home of the
Re: MOBIL ONE 0-50 wt [Re: HEMIFRED] #986087
05/04/11 03:01 PM
05/04/11 03:01 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
what time slip???
Re: MOBIL ONE 0-50 wt [Re: DJVCuda] #986088
05/04/11 03:10 PM
05/04/11 03:10 PM
Florida STAYcation
Florida STAYcation
what time slip???
The TIME the Lightning the CAPS
Re: MOBIL ONE 0-50 wt [Re: HEMIFRED] #986089
05/04/11 03:42 PM
05/04/11 03:42 PM
NC
440Jim Offline
440Jim  Offline
NC
I don't know about that oil in particular.
But in general multiviscosity oils don't hold their hot viscosity as long as straight weight oils. So with such a large multi-vis rating, it might suffer from viscosity breakdown sooner. But if you change it every week or so, that shouldn't be a factor.
Re: MOBIL ONE 0-50 wt [Re: 440Jim] #986090
05/04/11 06:34 PM
05/04/11 06:34 PM
SOUTH JERSEY
HEMIFRED Offline OP
HEMIFRED  Offline OP
SOUTH JERSEY
at 9.99 per qt.
home of the
Re: MOBIL ONE 0-50 wt [Re: HEMIFRED] #986091
05/04/11 07:40 PM
05/04/11 07:40 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
Even at $9.99 a quart, you can still get more out of it than a gallon of fuel.
Re: MOBIL ONE 0-50 wt [Re: HEMIFRED] #986092
05/04/11 10:42 PM
05/04/11 10:42 PM
Greenville, WI
Big B Offline
Big B  Offline
Greenville, WI
at 9.99 per qt.
It would be a good oil for a Le Mans type car. For a drag car why bother
Re: MOBIL ONE 0-50 wt [Re: Big B] #986093
05/05/11 12:12 AM
05/05/11 12:12 AM
SOUTH JERSEY
HEMIFRED Offline OP
HEMIFRED  Offline OP
SOUTH JERSEY
I would think LeMans race would be more harsh on an oil than any drag race.
Mobil 1 Racing 0W-50 is recommended for a wide range of race engine applications including highly loaded flat tappet designs such as NASCAR Cup engines.
I would include NASCAR as being more harsh
Features & Potential BenefitsApplications
Boosted levels of anti-wear protection — well beyond those of ordinary automotive oils Helps protect engines even during grueling racing applications.
Helps maximize power output by reducing internal friction.
Reduces internal friction Helps maximize power output.
Outstanding shear stability and a robust additive package Helps reduce oil breakdown and help to extend engine life, even under some of the most extreme conditions.
Compared to conventional racing oils and higher-viscosity synthetic motor oils Provides faster flow to critical engine parts at low temperatures.
High-temperature protection Helps deliver exceptional high-temperature protection, even at temperatures in excess of 400ºF (204ºC).
oh yea per qt. cost of 1 or 220 qt.( 55 gal ) same price 14.00
home of the
Re: MOBIL ONE 0-50 wt [Re: HEMIFRED] #986094
05/05/11 07:44 AM
05/05/11 07:44 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
I would save the 0 weight oils for the Comp eliminator racers and the like!
Alan Jones
Re: MOBIL ONE 0-50 wt [Re: LA360] #986095
05/05/11 08:44 AM
05/05/11 08:44 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Isn't that true of all syntho oils?
Coming soon!!!!
Re: MOBIL ONE 0-50 wt [Re: Mr.Yuck] #986096
05/05/11 10:33 AM
05/05/11 10:33 AM
Left Coast
BobR Offline
BobR  Offline
Left Coast
I used to be a big believer in synthetic oil but now I think that generally it's a waste of money.
Re: MOBIL ONE 0-50 wt [Re: BobR] #986097
05/05/11 11:03 AM
05/05/11 11:03 AM
Western New York
sixpackbee Offline
sixpackbee  Offline
Western New York
I have done a lot of oil testing in my Stockers and for the most part Bob is right. Between the fastest oil and the old Napa 75-100 10W40 Valvoline based dino oil there is .07-.09. In a class car that is a ton but for a bracket car I do not know if I would spend the extra money. I have found RP #9 to be the best compromise for cost, ET, and durability. I do change out for heads up runs though.
1959 Bugeye Sprite
1967 Charger Black L code
1967 Coronet R/T Convert Green 440 auto bought from original owner
1968 Charger R/T Bronze 440 4 spd console AM/FM
1969 Super Bee WM21H B5 A40 D21 N96
1969 Barracuda Formula S 340 Convert pilot car
1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85
1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96
1970 Road Runner RM21N B3 V1X D13
1971 MG Midget
1971 Road Runner RM23H GW3, A57
1972 Road Runner RM23P FY1, D21
Re: MOBIL ONE 0-50 wt [Re: sixpackbee] #986098
05/05/11 05:20 PM
05/05/11 05:20 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
If you compare with a synthetic blend 5w20 there will be only 2-3 hundredths difference. It's really just the lighter viscosity that allows the gains. When I ran my stocker we only found a couple of hundredths using 5w20 Mobil One over a generic 10w40. When you start getting real light expect to see more engine wear.
Re: MOBIL ONE 0-50 wt [Re: BobR] #986099
05/05/11 06:24 PM
05/05/11 06:24 PM
michigan
sturmenater Offline
sturmenater  Offline
michigan
does that price include a reach around.
I will stick with the brad penn
Re: MOBIL ONE 0-50 wt [Re: HEMIFRED] #986100
05/05/11 07:09 PM
05/05/11 07:09 PM
tn
robnbird Offline
robnbird  Offline
tn
I'll stick with valvoline racing oil or pensoil. They both have a high zinc content. even rotella 15w 40 diesel oil has a high zinc count. If you can prove senthetic oil lubes or lasts longer I'll use it.
Re: MOBIL ONE 0-50 wt [Re: BobR] #986101
05/05/11 11:17 PM
05/05/11 11:17 PM
Western New York
sixpackbee Offline
sixpackbee  Offline
Western New York
Here is what I found. 340 stockers mind you. Mobil 1 0W20 is .03 better than 75-100 Napa 10W40 dino oil. RP9 is .02-.03 better than the Mobil 1. The fast stuff we have is .03 better than #9. I have tested a blend of Gibbs oil that is pretty darn good.
1959 Bugeye Sprite
1971 MG Midget
Re: MOBIL ONE 0-50 wt [Re: sixpackbee] #986102
05/06/11 08:33 PM
05/06/11 08:33 PM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
Hi Holgar.
Care to elaborate a bit?
Thanks.
On the Gibbs stuff...
