Re: 440source flywheel on external balance 360LA??
[Re: mshred]
#985766
05/06/11 12:29 AM
05/06/11 12:29 AM
Posts: 1,044 Slidell, La.
doctor_mopar
Slidell, La.
If it looks like the correct weight that came with your flywheel, it must be it. I am going by faded memories of the installation I did, and of course it was the little big block weight I bought and installed. I think I recall being told by 440 source that the weight with the flywheel was non magnum 360.
------------------------ It doesn't matter what you do.........As long as you look good doing it !
[Re: doctor_mopar]
#985767
05/06/11 05:28 PM
05/06/11 05:28 PM
Posts: 3,421 Toronto
mshred
Toronto
well I just called 440 source again and sure enough they said they are not sure. I was put on hold so that he could ask their tech guy, and the tech guy said its the same for both small and big blocks (obviously wrong as I know now). So now im not sure what the heck to do. That weight is 35 bucks that I may not need to spend from looking at these pictures
Im wondering if I weigh the weight that I have if it will have all of the off balance weight in it, or if where it is mounted and such makes a difference...what i mean is will weighing just the weight tell me if it will work or not?
Anybody know?
[Re: mshred]
#985769
05/08/11 12:53 AM
05/08/11 12:53 AM
doctor_mopar
Slidell, La.
If that weight info is correct, you should be able to just trim some material off your weight. Weigh it as you go , till you get it right. Sounds like the weight that came with the flywheel was for a magnum motor.
