Re: 588" boat closer, a few pics.
[Re: galen]
#985644
05/03/11 08:32 PM
05/03/11 08:32 PM
Posts: 836 Missouri
galen
Missouri
[Re: galen]
#985645
05/03/11 08:33 PM
05/03/11 08:33 PM
Posts: 836 Missouri
galen
Missouri
[Re: galen]
#985646
05/03/11 08:34 PM
05/03/11 08:34 PM
Posts: 836 Missouri
galen
Missouri
[Re: galen]
#985647
05/03/11 08:38 PM
05/03/11 08:38 PM
Posts: 836 Missouri
galen
Missouri
[Re: galen]
#985655
05/04/11 07:02 PM
05/04/11 07:02 PM
That engine looks scarier that michael meyers. Awesome.
#985656
05/05/11 12:37 AM
05/05/11 12:37 AM
Posts: 1,049 San Jose Ca.
boatracer572
San Jose Ca.
Hey Galen, was wandering did you pick up lifeline or equil.chute or non chute jacket? Tony
[Re: boatracer572]
#985657
05/05/11 01:44 AM
05/05/11 01:44 AM
Posts: 836 Missouri
galen
Missouri
Tony I went with the Lifeline non chute jacket, goggles and open face helmet. Very nice people to deal with. Wife is measuring for my ballistic shorts tomorrow. I sure like that dolly trailer , Nice operation you have Tony. galen
[Re: dOc !]
#985660
05/05/11 02:36 AM
05/05/11 02:36 AM
Posts: 836 Missouri
galen
Missouri
Hay g ....could you(or would you have rather) have used that Nicson plate ...or was the belt-drive in the original plan ? do you have a pic of the prop ?
Doc it was a combination of the belt drive and I am going to try and run a heat exchanger using anti freeze in the block loop instead of running lake water in the engine. I am just running lake water through the heat exchanger tubes only. I am hoping I can control my engine temp a little better this way and keep corrosion out of the block and heads. I had originally looked into a cover like yours and was having trouble locating one. I found listings but when I called came up empty. I will try and dig up a picture of the prop. It is a 11x17 3 blade cleaver for a hydro. Got it from Tom Bentley at Menkins V-drive.
