? Fuel pressure gauge install? #984974
05/02/11 04:23 PM
05/02/11 04:23 PM
Bel Air Maryland USA 21014
wmwalden Offline OP
wmwalden  Offline OP
What do you guys use to install a fuel pressure gauge.
I just got AN-4 stuff. But it looks to big. I was thinking of something smaller. And want to know what racers use.
Bill
Re: ? Fuel pressure gauge install? [Re: wmwalden] #984975
05/02/11 05:12 PM
05/02/11 05:12 PM
Central Oregon
Rodney Offline
Rodney  Offline
Central Oregon
Just did install a fuel gauge mounted outside the cab and used steel braided 4-an.
Re: ? Fuel pressure gauge install? [Re: Rodney] #984976
05/02/11 05:30 PM
05/02/11 05:30 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I would use an AN-2 line with a .020 orfice, if the line breaks, you wont have gallons of gas sprayed all over. Tim
Re: ? Fuel pressure gauge install? [Re: astjp2] #984977
05/02/11 07:00 PM
05/02/11 07:00 PM
Central Oregon
Rodney Offline
Rodney  Offline
Central Oregon
ok that's a good point!
I was somewhat concerned having that fuel gauge / line pointing right at me
Re: ? Fuel pressure gauge install? [Re: Rodney] #984978
05/02/11 07:35 PM
05/02/11 07:35 PM
Az
Crizila Offline
Crizila  Offline
Az
I went with AN-4 stuff. A lot more fittings and hoses ( push-loc ) to chose from than -2 stuff.
Fastest 300
Re: ? Fuel pressure gauge install? [Re: Crizila] #984979
05/03/11 10:51 AM
05/03/11 10:51 AM
wmwalden Offline OP
wmwalden  Offline OP
I just ordered a teflon AN3 line.
Going from the regulater to the gauge mounted up by the windshield. I want to see how much fuel pressure I have when going throu the lights.
Thanks for the replys.
Re: ? Fuel pressure gauge install? [Re: wmwalden] #984980
05/03/11 11:17 AM
05/03/11 11:17 AM
Central Oregon
Rodney Offline
Rodney  Offline
Central Oregon
Is that line a small orifice like Tim recommended?
If so where did you order and could you give me the part number?
I also have a regular steel braided line for the oil pressure gauge mounted in the car. It would seem like a good idea to also have a small orifice line to the the oil gauge as well.
Thanks for the post.
Re: ? Fuel pressure gauge install? [Re: Rodney] #984981
05/03/11 04:16 PM
05/03/11 04:16 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Most people I know use a brass fitting that is pipe to flare, solder it closed and use a pin drill to make a small hole in the solder. Aircraft use the same type of fitting on their oil sending lines. If the line breaks, it gives the pilot more time to make an emergency landing before the sump is empty. Dont forget to bleed the line. Tim
Re: ? Fuel pressure gauge install? [Re: astjp2] #984982
05/04/11 11:13 AM
05/04/11 11:13 AM
wmwalden Offline OP
wmwalden  Offline OP
The AN-3 Teflon is actually 3/16 ID or very close. I bought the line from a local hardware store that makes industrial type lines and hoses.
Re: ? Fuel pressure gauge install? [Re: astjp2] #984983
05/04/11 12:30 PM
05/04/11 12:30 PM
Central Oregon
Rodney Offline
Rodney  Offline
Central Oregon
Thanks Tim sounds like good and inexpensive advice/insurance.
Re: ? Fuel pressure gauge install? [Re: Rodney] #984984
05/05/11 11:52 AM
05/05/11 11:52 AM
wmwalden Offline OP
wmwalden  Offline OP
I picked up my line yesterday. The orifice is about 1/8 inch in the fitting.
They crimped the ends on for me. The line looks perfect. 7'-6" long, 2 SS ends and labor $61.35. Seemed a bit high, but got what I wanted.
All
I will be racing at Englishtown next weekend at the Mopar Event.
Hope to see a few of you guys there.
