Re: Most powerful available water pump for BigBlock??
[Re: 1964Polara]
#984741
05/02/11 01:33 PM
05/02/11 01:33 PM
Posts: 3,291 West Coast, USA
jbc426
West Coast, USA
Why do you want such a powerful pump? It takes more pwer to spin it, and the stock pumps work just fine if the rest of the cooling system is up to par.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#984742
05/02/11 02:30 PM
05/02/11 02:30 PM
Challenger 1
Cincinnati, Ohio
Yup, the title of your post tells me something else is wrong with your cooling system, not the pump, unless you have the wrong pulleys on it.
[Re: 6T4 Polara]
#984745
05/02/11 08:06 PM
05/02/11 08:06 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
Went with the one for AC car.Don't know if it is the most powerful,had more vanes.
John
If it is a factory AC pump it actually has less vanes.
[Re: 62maxwgn]
#984746
05/02/11 09:50 PM
05/02/11 09:50 PM
Posts: 1,379 Houston,Tx.
Lee446
Houston,Tx.
I have had good luck with the Flow Kooler hi volume pump. On my Hemi with the factory aluminum pump and housing, I noticed that the temps would creep up when sitting in traffic, good 7 blade therm clutch fan on 26" alum radiator with shroud. At home with the cap off, I noticed that I could not really tell when the stat opened at 180, just was not any discernable flow at 800 rpm. I found that if I idled it up to around 1100, you could see good return flow across the top of the tank. This is where a high volume pump can be usefull, and yes, it does have the proper water pump pulley on it.
[Re: NV69B7RR]
#984748
05/03/11 09:23 AM
05/03/11 09:23 AM
RapidRobert
What Challenger 1 said, post what's going on. Need 3-4 core rad, unobstructed airflow to/thru it, high flow stat, mixture/timing in the ballpark, & 8 vane Eddy (or similar) pump, tight fitting shroud w properly spaced fan. I believe the faster the water speed the better & when 1 block of water in the rad leaves faster and gets cooled less the next block enters faster to b cooled quicker so in a closed system it reaches an equilibrium till it reaches the point of no addt'l gain no matter how fast it is going and cavitation will start b 4 you reach that point. But on the other end if it is too slow it'll easily reach a point where if it is too slow not enough vol of water is going thru the rad being cooled. Want at least 1 to 1 crank to wp ratio. Add the anti cav plate & best is one thick enough to reduce the distance to the recessed area in the housing for a more efficient pump and if apart can drill a 3/8" to 1/2" addt'l cooling hole in the block/head (punch dont drill the gasket as it'll shred it) in between cyls 4-6 and 3-5 just above/next to, the 2 outside bolt holes on the outside edge (make a triangle) as that is the hottest area being between 2 paired ex valves.
[Re: RapidRobert]
#984750
05/03/11 10:24 AM
05/03/11 10:24 AM
62maxwgn
Blair County,PA
Or you could go with all the original components it rolled of the assembly line with and never look back,everything worked!! ![](/ubbthreads/images/graemlins/no.gif)
[Re: 62maxwgn]
#984751
05/03/11 10:42 AM
05/03/11 10:42 AM
Posts: 10,246 Someplace you aren't
SomeCarGuy
The Edelbrock pump is a great piece. I have had them on two different cars and they work great.
I want my fair share
[Re: 62maxwgn]
#984754
05/04/11 08:03 AM
05/04/11 08:03 AM
Posts: 5,278 San Jose, California
DennisH
Vacation
Vacation
That's right. Ma knew.
[Re: NV69B7RR]
#984757
05/05/11 06:05 AM
05/05/11 06:05 AM
Posts: 1,285 Pacific NW USA
CompSyn
Pacific NW USA
DEFINATELY NOT A 440SOURCE pump!!
Curious? Why is that?
[Re: 1964Polara]
#984758
05/05/11 12:39 PM
05/05/11 12:39 PM
Posts: 28,078 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
A guy did a multiple pump test on a RB powered motorhome. He tested all kinds of pumps and measured the flow. You would be surprised how little difference there was between pumps. In short, a stock water pump worked better than many aftermarket pumps. ****EDIT**** Found the info on dodgecharger.com. It starts about half way down this page: http://www.dodgecharger.com/forum/index.php?PHPSESSID=u7bt37m2253qmcubqcm0vmbqa2&topic=60599.175
