Re: comparison 440-2 -440-25 anyone done it
[Re: dvw]
#984469
05/17/11 08:15 AM
05/17/11 08:15 AM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
I have dynoed both avs and afb's and the metering is same the only difference is the ability to adjust the secondary air dam which only effects when throttle is cracked open. When dynoing that intake With egts we did not find any cyl that was off from others. Jake
JAKES AUTOMOTIVE
[Re: fast68plymouth]
#984470
05/17/11 09:18 PM
05/17/11 09:18 PM
Posts: 14,603 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
ive posted these before a few years ago......but for a recap.... 440-3 with a 1050 carb
#984472
05/17/11 09:23 PM
05/17/11 09:23 PM
fast68plymouth
So. Burlington, Vt.
440-25 w/2 X 750's with 119 jets in all 8 holes. notice the fuel flow #'s on all 3 pulls. it took that much jet to get the flow 's close to where it was with the 1050 carb on the single plane intakes.
