Page 3 of 3 1 2 3
Re: Distributor Cap Blow off [Re: Caparco] #983804
05/31/11 10:37 PM
05/31/11 10:37 PM
Lose rotor?.. how to fix?.. test?
up/down play in the dist shaft. Dist bottom side lower shaft/Drive out the roll pin/remove the plastic collar/add 1/2" ID flat metal washers till the end play is near zero/reinstall collar/roll pin
Re: Distributor Cap Blow off [Re: RapidRobert] #983805
05/31/11 10:39 PM
05/31/11 10:39 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
yeah ok.. plastic collar on dist could have broke allowing shaft to come up and pop it off too.. pull dist real quick if you havent allready dan
Re: Distributor Cap Blow off [Re: Caparco] #983806
05/31/11 10:47 PM
05/31/11 10:47 PM
Newfoundland
mopar_man Offline
mopar_man  Offline
Newfoundland
No this is not when I start.. starts fine.. its when you really give it the gas.. from a stop or passing on highway
and I can't make it pop off in park reving the engine or with my head under the hood , in fear of damaging something!
And blowing off isn't real correct.. the 2 clips stay on and it just cocks to one side.. throwing the timing way off.. popping and choking un- drivable
someone said tie it down... but I really don't like this at all!!..LOL may work, ill have to see when i get her running but isn't this a electrical hazard!!.. lol got to be a better answer!
Looks to me that you have a wrong clip on the right side of the pic. i don't think it will seat in the groove correctly.
the left clip seems to be the correct one. as a matter of fact the cap doesn't look just right . are you sure the cap is fitting in the groove/notch of the dist ?
Also the vent in the cap is not to vent gases , its there to keep the cap free of moisture by equalizing the humidity outside to inside .
Bottom line ..........looks like a clip problem
Re: Distributor Cap Blow off [Re: Caparco] #983807
05/31/11 11:48 PM
05/31/11 11:48 PM
get a good cap and a pair of clips from a junk dist & I'll bet my next to last buck this prob will b behind you
Re: Distributor Cap Blow off [Re: Challenger 1] #983808
06/01/11 12:50 AM
06/01/11 12:50 AM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
I wd40'd my weights once, fired it up and,..POW! blew the sucker right off. Thats the closest I've seen.
Even better when the shop "flunky" uses brake clean!!! You otta see the mess it makes!!!
Re: Distributor Cap Blow off [Re: Caparco] #983809
06/01/11 08:59 AM
06/01/11 08:59 AM
scratchnfotraction Offline
pull the cap,look and note which way your rotor is pointing.
pull the dist,go get a new reman one from autozone for around 30 bux.
install it with rotor faceing the same way.
should take care of the bent/wrong clips and worn shaft bushing in the one you have.
Re: Distributor Cap Blow off [Re: scratchnfotraction] #2828436
10/03/20 09:17 PM
10/03/20 09:17 PM
Rhode Island
Caparco Offline OP
Caparco  Offline OP
Rhode Island
Looking back at my old post. LOL
Hindsight is 20/20
Golden-Arm was right from the start.
It was spent motor mount. Engine lifted up and got pushed off
~ 72 Dodge Challenger ~
~ 97 Dodge Neon ~
~ 97 Dodge Ram ~
Re: Distributor Cap Blow off [Re: Caparco] #2828444
10/03/20 09:45 PM
10/03/20 09:45 PM
BDW Offline
BDW  Offline
Better late than never, nice update 9 yrs later
Page 3 of 3 1 2 3
